Any good sources for starter motors (without gearbox/solinoid)?
A user is seeking a DC motor in the 3-3.5kW, 12-24V range, ideally 24V, for short bursts of power, emphasizing the need for a small, lightweight, and inexpensive option under $100. Starter motors are considered suitable but are typically priced between $100-200. The discussion includes suggestions to check truck scrapyards for used starters that meet the specifications. However, it is noted that finding a motor with the desired torque and reliability for under $100 may be unrealistic. The conversation highlights the challenges of sourcing affordable starter motors or equivalents without additional components.
LimitedSlip7
I'm trying to find a DC motor in the 3-3.5kW 12-24V range (Preferably 24V) for a project that will utilize the motor at maximum power for occasional short bursts of maybe 2-3 seconds in duration at most. The motor needs to be fairly small, lightweight, and CHEAP ($100 or less). Starter motors exactly fit what I am looking for, but are still kind of pricey ($100-200). Does anyone know of a good source that sells starter motors or an equivalent without the gearbox/solenoid/etc in the price range I am looking? The RPM range is not very important, but the higher RPM the better. Also, brush/magnet types are not important either.
If not, what about a common vehicle that uses a starter with those specs that I could source used starters from?
Thanks!
Truck scrapyard.
In any event, expecting a motor which can offer the torque and reliability of a starter motor for under $100 is pretty unreasonably.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
