Proving Rational Numbers: Multiplication Axioms & Contra
  • Thread starter Thread starter Zero266
    Analysis
Zero266
Prove using the multiplication axioms that if x is not zero, then 1 / (1/x) is equal to x.
Prove that there is no rational number, p, such that p^2 = 12
I know for all x there exists x^-1 such that xx^-1 = 1 but i don't know how to use that to prove the first one.
For the second one, I understand the proof for p^2 = 2 by contradiction by showing that it was not reduced to lowest term because both a and b in a/b turned out to be even, but i can't seem to duplicate the process for 12.
For the first one, it's a good idea to show that multiplicative inverses are unique, but I don't think you need to (someone else will correct me if I'm wrong).
Basically, you need to first check that if x =/= 0, then (1/x) =/= 0. You can do this by contradiction. Then you basically apply the multiplicative inverse property to (1/x), and you can do this because you have established (1/x) =/= 0.
Eh, the duplication process should be the exact same thing. There are a lot of ways to do this since 12 has a few divisors. Suppose (a/b)^2 = 12, then a must be divisible by 12. So let a = 12k.
EDIT: Actually, it's somewhat important to show that multiplicative inverse are unique. Perhaps the easiest way to do this is by proving that if S is a field and x,y are elements of S with x =/= 0 and xy = 1 for all x,y, then y = x^-1. This follows almost immediately from the axiom.
Thanks a lot. Maybe I'm just stupid, but why is "a" a multiple of 12? (a/b)^2 = 12, so a^2 is certainly a multiple of 12, but I'm not really convinced a is. are you using an axiom? if so which one or ones ? Thanks! ><
Hmmm, well a = 12k implies a2 = 144k2 = 12(12k2) so a2 is divisible by 12. Now we can let k \geq 1, so that if a2 is divisible by 12, then a2 = 12(12k2) = (12k)2. Then it's easy to see that the converse holds as well.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
