Looking for algoritm to the partition problem C
  • Thread starter Thread starter transgalactic
    Partition
The discussion focuses on creating a recursive function, int partition(int arr[], int size), that determines if an integer array can be split into two groups with equal sums. An example provided illustrates that the array {1,2,2,3,5,6,1} can be divided into two groups, both summing to 10, which would result in the function returning 1. The requirement for recursion without loops and the restriction against using pointers raises questions about how to retain calculated values across recursive calls. The conversation touches on the educational emphasis on recursion in computer science courses, suggesting that while it may not reflect practical programming, it is a common academic exercise. There is also a concern about how to manage state without pointers, hinting at the potential use of static or global variables, although their use in this context remains unclear.
transgalactic
write a function called
Code:
which input an array of integers and decides whether
it is possible to divide the array into two groups
so the sums of both the groups will be equal.
Code:
for example arr = {1,2,2,3,5,6,1}
its could be divided into {2,2,6}  and {1,1,3,5} both of their sums is 10
so they are equal and the function needs to return 1.
the function must be recursive without loops.
you are allowed to use only one external recursive function
and i can't use pointers
i tied to build a code that sums for ranges
but the example shows that there could be a possibility
of two sub sequences mixed with one another
so the range option is not solving this
Technology news on Phys.org
Why does the method have to be recusive? Why can't you use pointers?
Because CS homework always involves recursion - CS teachers still thinks it's cool.
Fortunately almost all CS grads remember nothing they have learned so don't try and use it in the real world.
Well then, a little more coded form would help understand the task at hand. For example, since no references or pointers are allowed, how do you intend to retain a calculated value between calls...a member variable or possibly a static or global variable, or are these off limits also?
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
Thread 'Project Documentation'
Trying to package up a small bank account manager project that I have been tempering on for a while. One that is certainly worth something to me. Although I have created methods to whip up quick documents with all fields and properties. I would like something better to reference in order to express the mechanical functions. It is unclear to me about any standardized format for code documentation that exists. I have tried object orientated diagrams with shapes to try and express the...
