Calculating Impact Force of an Arrow on Target
The discussion revolves around calculating the impact force of an arrow traveling at 100.6 m/s and weighing 22.68 g on an archery target. It highlights that the force exerted by the arrow depends on how quickly it decelerates to a stop, with steel targets generating higher forces than softer materials like cork. However, participants conclude that the force of the arrow is negligible compared to external factors like wind or vandalism, making the exact force value less critical for target design. Ultimately, the focus shifts away from the force calculation to practical considerations for target durability. The thread concludes with a decision to close the discussion.
x-ten
This may be more of an engineering question, but here goes:
I am designing an archery target and am trying to establish the impact force of the arrow on the target.
The arrow is traveling at 100.6m/s and weighs 22.68g, what would be the force of the arrow on the target?
How does this force then translate to the target frame? (since i am trying to work out what steel to use) or is this force going to be almost negligible even on small thickness sections of steel?
thanks,
Anthony
Depends on how long it takes to slow the arrow down to 0 mph. The force is higher with a steel target than with a cork target.
And what would knowing the force value do for you?
Thanks for responding John,
After talking to a few people, i have found that the force of the arrow will be negligible compared to the wind or vandals, so it won't really do much for me to know the arrow's force :rolleyes:
Please consider this thread closed.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
