Riemann Geometry: Where is the Flaw in My Thinking?
  • Thread starter Thread starter Gear300
    Geometry Riemann
Riemann's geometry asserts that any two lines meet, which raises questions about the behavior of longitudinal lines on a sphere. The discussion clarifies that longitudinal lines, while they may seem parallel, actually intersect at the poles, aligning with Riemann's principles. A participant reflects on a past inquiry regarding the definition of parallel lines, emphasizing the necessity of the parallel postulate in geometry. The conversation highlights the distinction between straight lines and curves, noting that lines of latitude are equidistant curves on a sphere. Overall, the discussion reinforces the complexities of geometric definitions and their implications in Riemannian geometry.
Gear300
One of the axioms of Riemann's geometry holds that there are no parallel lines and that any two lines meet. Since Riemann's geometry fits for that of a sphere, any two great circles of the sphere should intersect. However, if we were to take 2 longitudinal lines, then it is possible that these lines never meet. Where is the flaw in my thinking?
Mathematics news on Phys.org
Never mind...I overlooked how the longitudinal lines are not by definition "straight" lines.
Specifically, they aren't great circles.
You mean latitude?
Office_Shredder said:
You mean latitude?
Good point. "Longitudinal lines" isn't clear but since he referred to them never meeting, I assumed that was what he meant. "Lines of constant longitude", of course, meet at the north and south poles.
By the way, back many many years ago, when I was in high school, I asked my geometry teacher, "why not just define 'parallel lines'" as being lines a constant distance apart? Then it would be obvious that they don't meet and there is only one 'parallel' to a given line through a given point". Being a high school teacher he pretty much just brushed off the question. Now I know that you need the parallel postulate to prove that the set of points at constant distance equidistant from a given line is a "line". The set of lines of lattitude are examples of "equidistant curves" on the spere.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
