Optimizing Channel Section Tolerances for Pin Jointed Machine Design
  • Thread starter Thread starter Mech King
    Channel Section
The discussion centers on challenges faced in achieving consistent dimensions with BS10279:2000 Hot Rolled Steel Channels for a pin jointed machine design. The primary issues include variability in flange flatness and thickness, which complicates drilling and increases costs. Suggestions include exploring ASTM A6/6M for tighter tolerances and considering custom extrusions, although the latter may be more expensive. There is also a consideration of using aluminum sections, but concerns about strength and cost persist. Ultimately, the need for better quality materials may necessitate higher expenditures to ensure design integrity.
Mech King
I am deisigning a pin jointed machine that uses some standard channel section. I am having difficulty getting consisitency with the channel section (type BS10279:2000 Hot Rolled Steel Channels) dimensions due to the wide nominal tolerances.
Is anyone aware of any channel/U -Section that has much tighter tolerances over the flatness, height, length, thickness, radius' etc?
I dont' want to resort to welding jigged sheet steel together to obtain the correct dimensions.
If anyone is aware of anything then i would be more then greatful,
Cheers
Mech King
The only thing I know of is ASTM A6/6M which pretty much spells out the variations allowed in shapes and plates.
Just what kind of tolerances/problems are you wanting/experiencing? Could anything be solved by so,e properly selected limited local machining processes?
Hi Fred cheers for the reply,
my main issue has been with flatness of the channel flanges - which when drilling concentric holes, has become a more time consuming process with the obvious associated costs. Also, the flange thickness varies by about +/- 1.5mm if i remeber correctly, and if both flange thicknesses are out the the clearence will be greatly increased or reduced. Just wanted to get more consistency with it because each length of channel is widely different from the other it would seem.
I will okk into what you specified and see if i can get tighter tolerances.
cheers again
Mech king
Yeah. That's pretty much the run of the mill (pardon the pun). I honestly have never seen anything better that wasn't a custom extrusion.
Does it have to be steel? There are some more expensive, but mass produced aluminum sections that would fit your needs.
The Aluminium section will be too weak for the design, its a mechancial lift, i think i may be able to get away with AL section though, if i down-rated the max weight of the lift - which wouldn;t be out ofthe question. I also wanted to keep the lift as cheap as possible, but if it means i need to spend more to get better quality then that might have to be the way forward - i gues you can't have eberything in the quality, cost and time triangle lol.
Cheers
mech King
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
