Solving Limits: $\lim_{x\rightarrowy}\frac{sin{x}-sin{y}}{x-y}
  • Thread starter Thread starter Laven
    Limits
The discussion revolves around solving the limit $\lim_{x\rightarrow y}\frac{\sin{x}-\sin{y}}{x-y}$. Participants suggest using trigonometric identities and L'Hôpital's rule to simplify the expression. One user points out the importance of correctly applying the sine difference identity, which can help in breaking down the limit. Another participant emphasizes that L'Hôpital's rule might be a simpler approach to tackle the limit problem. The conversation highlights the need for clarity in mathematical notation and the application of relevant mathematical techniques.
Laven
so this is the question.
I'm here solving this problem you please check where am i wrong or next idea I've to use here.
=\lim_{x\rightarrowy}\frac{sin{x}-sin{y}}{x-y}x\frac{cos{x}+cos{y}}{cos{x}+cos{y}}
=\frac{sin{x}cos{x}-sin{y}cos{y}+sin{x}cos{y}-cos{x}sin{y}}{{x-y}{cos{x}+cos{y}}
=\lim_{x\rightarrowy}\frac{sin{x}cos{x}-sin{y}cos{y}+sin{x-y}}{{x-y}{cos{x}+cos{y}} +\fracsin{x-y}{(x-y)(cos{x}+cos{y})}[/tex]
after this i don't 've idea wht to do.Is there next idea we have to include overhere?
Mathematics news on Phys.org
=\lim_{x\rightarrowy}\frac{sin{x}-sin{y}}{x-y}\frac{cos{x}+cos{y}}{cos{x}+cos{y}}
The "x" you had in the middle here was just "times" wasn't it? Better not to use such a symbol along with"x" as a variable.
=\frac{sin{x}cos{x}-sin{y}cos{y}+sin{x}cos{y}-cos{x}sin{y}}{(x-y)(cos{x}+cos{y})}<br /> =\lim_{x\rightarrow y}\frac{sin{x}cos{x}-sin{y}cos{y}+sin{x-y}}{(x-y)(cos{x}+cos{y})} +\frac{sin(x-y)}{(x-y)(cos{x}+cos{y})}<br /> <br /> after this i don&#039;t &#039;ve idea wht to do.Is there next idea we have to include overhere?[/QUOTE]<br /> I think I have corrected your LaTex properly. sin(x- y)= sin(x)cos(y)- cos(x)sin(y) and you appear to be trying to put the numerator in that form. (It would be a good idea to explain things like that when asking about a problem.) You wind up with two parts:<br /> \frac{sin x cos y- cos x sin y}{x- y}= \frac{sin(x-y)}{x- y} <br /> which goes to 1 as x goes to y, and <br /> \frac{sin x cos x- sin y cos y}{x- y}<br /> which is still a problem.<br /> <br /> It would be far simpler to use L&#039;Hopital&#039;s rule. Are you allowed to do that?
=\lim_{x\rightarrowy}\frac{sin{x}-sin{y}}{x-y}*\frac{cos{x}+cos{y}}{cos{x}+cos{y}}
=\lim_{x\rightarrowy}\frac{sin{x}cos{x}-sin{y}cos{y}+sin{x-y}}{(x-y)(cos{x}+cos{y})} +\fracsin{x-y}{(x-y)(cos{x}+cos{y})}
here?
<br /> I think I have corrected your LaTex properly. sin(x- y)= sin(x)cos(y)- cos(x)sin(y) and you appear to be trying to put the numerator in that form. (It would be a good idea to explain things like that when asking about a problem.) You wind up with two parts:<br /> \frac{sin x cos y- cos x sin y}{x- y}= \frac{sin(x-y)}{x- y} <br /> which goes to 1 as x goes to y, and <br /> \frac{sin x cos x- sin y cos y}{x- y}<br /> which is still a problem.<br /> <br /> It would be far simpler to use L&#039;Hopital&#039;s rule. Are you allowed to do that?[/QUOTE]<br /> <br /> Yea that&#039;s what i meant to express in latex form.Thanks for your correction.<br /> <br /> Isn&#039;t it solved by that method?[method which i did]<br /> <br /> Umm..L&#039;Hopital&#039;s rule is it the best way to solve the problem?Thanks I don&#039;t &#039;ve idea bout that but i can get it after reading this rule.If not i&#039;ll again ask you.
Laven said:
Umm..L'Hopital's rule is it the best way to solve the problem?Thanks I don't 've idea bout that but i can get it after reading this rule.If not i'll again ask you.
Hi Laven! :smile:
You need to learn your trigonometric identities …
in this case sinx - siny = 2 sin((x - y)/2) cos((x + y)/2) :wink:
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
