Question on linearity of Lorentz transformations
66 replies · 13K views
facenian
Hello.The way the transformation of coordenates in Special Relativity are ussually derived presuposes linearity or try do demostrate such linearity using wrong arguments. For example some authors state that since linear and uniform motion remains linear and uniform after the transformation this fact imposes linearity, however this simply is not true as is demostrated(for instance) in J. Aharoni's "The Special Theory of Relattivity" where he shows a particular not linear transformation which transforms a uniform motion along a straight line into a similar kind of motion. Other authors simply state that the principle of relativity+homogeinity and isotropy of space-time imposes linearity but don't give details of how this come about.
Is there a correct,rigorous demostration for linearity from first principles, in which case where can one find it ?
Linearity is in fact a consequence of homogeneity.
Space and time intervals between two points should not depend on a particular point, so in
[tex]dx'^i = \frac{\partial x'^i}{\partial x^k} dx^k[/tex]
matrix [tex]\partial x'^i/\partial x^k[/tex] does not depend on x.
Try
Zeeman, E. C. "Causality Implies the Lorentz Group", Journal of Mathematical Physics 5 (4): 490-493; (1964).
I agree. The traditional "derivation" of the Lorentz transformation is mostly BS. It's not really a derivation at all. I've been complaining about that in lots of threads already, so I won't repeat everything here, but consider e.g. the claim that the principle of relativity implies that the group of functions that represent a change of coordinates from one inertial frame to another must be either the Galilei group or the Poincaré group. What we're really doing there is to take an ill-defined statement (the principle of relativity) and interpret it as representing a set of well-defined statements. Then we find out which of the well-defined statements that are consistent with all the other assumptions that we want to make. (One of those assumptions is linearity).
This is of course a perfectly valid way to find a set of statements that we can take as the axioms of a new theory, but to call it a "derivation" is preposterous.
No.
Noel Doughty, in his book Lagrangian Interaction, refers to a paper by Mariwalla, Uniqueness of classical and relativistic systems, Phys. Lett. A79 143-146.
"Mariwalla shows that this result [linearity of a boost] may in fact be established without appealing to homogeneity. This follows because there are only three distinct 1-parameter groups acting in one spatial dimension [i.e. along the direction of the boost], and all imply linear transformation equations." (Bracketed comments are mine.)
He also refers to derivations of the LTs from Am. Journ. Phys. 43 434-437 and 44 271-277.
The traditional derivation is not BS if one does not add the conclusion that the Lorentz transformations are the only way that works.
Edit: Would anyone feel better if instead of "traditional derivation", we said "traditional construction"?
Usual linear Lorentz transformations are applicable to coordinates of non-interacting particles (with linear uniform motion). However, they are not valid for coordinates of particles interacting with each other (if this interaction is described by Poincare-invariant Hamiltonian dynamics). This has been proved a long time ago
Currie, D. G.; Jordan, T. F.; Sudarshan, E. C. G., Relativistic invariance and
Hamiltonian theories of interacting particles, Rev. Mod. Phys. 35, 350-375
(1963).
http://puhep1.princeton.edu/~mcdonald/examples/mechanics/currie_rmp_35_350_63.pdf
(1963).
"two particles (not two particles and a field)"
Yes, Currie-Jordan-Sudarshan theorem has been proven only for directly interacting particles. If you believe that particles interact via some "field" mediation, then the CJS result does not apply directly. However, the idea of their proof suggests that even in the case of field-mediated interactions Lorentz transformations of particle observables must be non-linear and interaction-dependent.
The idea is that in any Poincare-invariant interacting theory boosts are represented by interaction-dependent operators in the Hilbert space (or their appropriate analogs in the classical phase space). Therefore, it seems very likely that the action of boosts on particle observables must be interaction-dependent (rather than given by universal linear Lorentz transformations).
In any case, it seems more logical to derive boost transformations of particle observables from underlying dynamical theory rather than postulate them from the beginning, as has been done in special relativity.
Thank you for your answers.
First I want tell quZz that what he said is not correct otherwise the time inteval between two events would be the same for all observers which is what happens in Newtonian physics.
I see there is a little controversy, Fredrik says there is no such rigorous derivation and ohers cite papers dealing with such derivations. Regretfully I don't have access to papers, I will try the link atyy suggested though
Can someone tell me what BS stands for?
By the way I see the discussion went beyound SR
George Jones said:
Try
Along those lines, there are also the theorems of A.D. Alexandrov
http://books.google.com/books?hl=en...ts=Gx4d8imeP5&sig=YZME-oNHVpD5hf-iwkWFov7Fsp8 [see theorem 1 and its corollary] (1967, with reference to one from 1953).
Of possible interest are the constructions of http://en.wikipedia.org/wiki/Alfred_Robb" ,
e.g. http://books.google.com/books?id=vp...YeY2EI&sa=X&oi=book_result&ct=result&resnum=6
http://www.archive.org/details/theoryoftimespac00robbrich (1914)
I'm sorry what I told quZz about why he is wrong is not correct. In fact I would like to know why his argument is incorrect in case it is.
I think I now know the answer why quZz's argument is wrong, what SR tells us is that only
[itex]ds^2=g_{ik}dx_idx_k[/itex] have absolute meaning not the [itex]dx_i[/itex] individually, what should be independent of space-time coordenates is [itex]ds^2 \,not\, dx_i[/itex]
facenian said:
Some authors state that since linear and uniform motion remains linear and uniform after the transformation this fact imposes linearity, however this simply is not true as is demostrated(for instance) in J. Aharoni's "The Special Theory of Relattivity" where he shows a particular not linear transformation which transforms a uniform motion along a straight line into a similar kind of motion.
I assume when you wrote that Aharoni's non-linear transformation transforms "a" uniform motion along "a" straight line into a similar kind of motion, that you meant to say it transforms ALL uniform motions along straight lines into similar kinds of motion. This is what is required of a transformation between inertial coordinate systems, so your statement wouldn't make sense unless you replace A with ALL.
For those of us who don't have access to Aharoni's book, can you state the non-linear transformation that transforms ALL uniform motion in straight lines into similar kinds of motion?
you may be right perhaps I shouldn't have said "a uniform" pardon my english. The transformation equations are :
[tex]x_i^{'}=\frac{a_{ik}x_k+b_i}{c_kx_k+d},\quad i=0,1,2,3[/tex]
where we've used Eintein's convention for repeated indices. Note that the denominator
does not depend on index "i".
A derivation is given using the product of ""purely kinematic and non-kinematic transformations"" in:-
Torretti, Relativity and Geometry (1984). Chapter3 section 3.4--The Lorentz Transformation. Einstein's derivation of 1905.
Matheinste
I recommend www.urbandictionary.com. :smile:
There are plenty of rigorous mathematical arguments that end with the Lorentz transformation, but what do they prove, really? They always start with assumptions that are so strong that you might as well have started with the Lorentz transformation right away.
The "standard" derivation that I'm talking about is the one that starts with Einstein's postulates. You definitely can't prove anything from Einstein's postulates, since they are ill-defined. The biggest problem with them is that they talk about inertial frames as if that concept has been defined already.
I don't think that works either. What I'd like to see is a clear statement at the start of the "derivation" that says that we're just trying to guess what might be appropriate axioms for a new theory.
Hi Fredrik,
I agree with you that existing "derivations" of Lorentz transformations are inadequate. Here are some examples that I am talking about:
H. M. Schwartz, "Deduction of the general Lorentz transformations from a set of necessary assumptions", Am. J. Phys. 52 (1984), 346.
J. H. Field, "A new kinematical derivation of the Lorentz transformation and the particle description of light", Helv. Phys. Acta 70 (1997), 542.
http://www.arxiv.org/abs/physics/0410062
R. Polishchuk, "Derivation of the Lorentz transformations",
http://www.arxiv.org/abs/physics/0110076
D. A. Sardelis, "Unified derivation of the Galileo and the Lorentz transformations", Eur. J. Phys. 3 (1982), 96
J.-M. Levy-Leblond, "One more derivation of the Lorentz transformation", Am. J. Phys. 44
(1976), 271.
A. R. Lee and T. M. Kalotas, "Lorentz transformations from the first postulate", Am. J. Phys.
43 (1975), 434.
In my opinion, their major flaw is that they are not applicable to systems of interacting particles. For example, if one uses the 2nd Einstein's postulate (the constancy of the speed of light), then the obtained Lorentz transformations can be logically concluded to be valid for events associated with light pulses only. If one uses the uniformity and linearity of free moving particles, then there is no guarantee that obtained Lorentz transformations will remain valid for interacting particles whose movement in non-uniform and non-linear.
Fundamentally, we are interested in boost transformations of particle observables (positions, momenta, etc.). In quantum mechanics, such transformations can be unambiguously calculated by applying the operator of boost to particle observables. So, in order to rigorously derive Lorentz transformations one first needs to build a Poincare-invariant dynamical theory of interacting particles. In relativistic quantum mechanics this means construction of 10 Hermitian operators (that correspond to 10 generators of the Poincare group and satisfy commutation relations of the Poincare Lie algebra), which represent total observables of energy, momentum, angular momentum and boost. Then applying the unitary boost operator to observables of individual particles, we can calculate the boost transformation formulas.
If we follow this prescription, we can immediately realize that universal linear Lorentz transformations cannot be obtained in the interacting case, because it is well-known that the total boost operator must be interaction-dependent. So, Lorentz transformations of special relativity should be regarded as an approximation acceptable only for weakly interacting particles.
A lot of interesting links =)
you misunderstood me. I'm not saying that dxi are absolute (have the same values for all observers), that's incorrect. The thing is that the value of dx' depend only on the value of dx but not on x itself, that's what homogeneity is all about. Same dx, different x -> same dx'.
What's wrong with them?
Well, we know that Lorentz invariance fails globally in general relativity, but it remains valid locally. Are you saying there is evidence of violation of Lorentz invariance locally? Many people have searched for such a thing, but as far as I know, there is no evidence that local Lorentz invariance ever fails. So I'm not sure what you mean when you say Lorentz transformations are only approximate.
Unfortunately, Lorentz transformations themselves cannot be directly measured. However, we can measure some of their consequences, e.g., the slowing-down of the decays of moving particles. Rigorous calculations show that this slowdown deviates from the Einstein's time dilation formula. However the deviations are several orders of magnitude smaller than the accuracy of experiments.
E. V. Stefanovich, "Quantum effects in relativistic decays", Int. J. Theor. Phys. 35 (1996), 2539. http://www.geocities.com/meopemuk/IJTPpaper.html
M. I. Shirokov, "Decay law of moving unstable particle", Int. J. Theor. Phys. 43 (2004), 1541
M. I. Shirokov, "Evolution in time of moving unstable systems", Concepts of Physics 3
(2006), 193. http://www.arxiv.org/abs/quant-ph/0508087
E. V. Stefanovich, "Violations of Einstein's time dilation formula in particle decays", http://www.arxiv.org/abs/physics/0603043
Hmm… Meopemuk, I think we exchanged through email some years ago. Now my understanding of SR is a little better and I am arriving at this conclusion, which I think is in line with yours:
- SR postulates that all clocks, also mechanical clocks, suffer the same TD effect. But in principle the classical reasoning seemed logically flawless. If two observers moving wrt each other, when they meet, shoot down two bullets from their respective guns, it seems they should arrive at their respective targets at the same absolute time. The bullets were stationary with their respective holders before they were shot, since they are moving inertially with them; when they are shot, they are shot by guns at rest with their respective frames and, finally, their motion is measured in each case against the reference of the corresponding frame…
- Light is different, ok, because it does not take the motion of the source, but then it seems that the TD effect should apply to light clocks, not to mechanical clocks, whose ticker does take the motion of the source.
- If the classical reasoning fails, as it does, since experiments prove it, it must be because it is actually flawed and the only reason I can think of is that it disregards the importance of the interaction causing the bullet to accelerate. And if this interaction is to be relevant in the sense required by SR, it must be because the same bears a resemblance with light: what causes the acceleration of the bullet is an electromagnetic interaction. There is a light clock at the heart of the interaction that makes a mechanical clock tick.
- In any case, this reasoning assumes that the electromagnetic interaction is pure, develops in an ideal way that is immune to physical circumstances, which might vary from case to case. If we could account for that with very precise instruments, we might find out that the rules are more complicated, in accordance with certain patterns…
Is that more or less in line with what you hold? Of course, these are bold speculations, at least on my side. (And if I were thus breaking forum rules, please anyone in charge let me know. I enjoy the forum too much to be banned…)
Yes quZz, I yust don't want to accept it could be that simple there mus be something wrong with it.
I want to tell Fredrik that I did not ask for somthing that rigorous. I yust wanted that some one tell me how first principles(relativity principle,homogeneity/isotropy of space-time) lead to Lorentz transformations,by the way according to L. D.Landau(Volumen I)
an inertial frame is one in which space is homogeneous and isotropic and time is homogeneus
I mentioned their biggest problem immediately after the text you quoted.
Hi Saw,
In my reasoning I am trying to stick to well-established postulates and what can be deduced from them by rigorous logic.
The fundamental postulate of any relativistic theory is the requirement of invariance with respect to the Poincare group. Another obvious fact is that the Hamiltonian (the generator of time translations in the Poincare group) of any multiparticle system contains interaction terms. By group theory arguments it follows that the generator of boosts must also contain interaction terms (see P. A. M. Dirac, "Forms of relativistic dynamics", Rev. Mod. Phys. 21
(1949), 392). So, when boosts are applied to particle observables, we are bound to find that the corresponding transformations are non-linear and interaction-dependent. It then follows that (linear and interaction-independent) Lorentz transformations of special relativity cannot be exactly valid in interacting systems, and that one should expect interaction-dependent corrections to Einstein's time dilation and length contraction formulas.
@facenian:
The transformation you provided does map straight lines to straight lines, but not uniform motion along straight lines to uniform motion along straight lines.
Ich said:
@facenian:
Yes, it does. Calculate carefully de folowing
[tex]V_{\alpha}^{'}=\frac{dx^{'}_\alpha}{dx^{'}_0} =\frac{\frac{dx^{'}_\alpha}{dx_0}}{\frac{dx^{'}_0}{dx_0}},\quad \alpha=1,2,3 \quad, and \, under\, the\, assumption\, \frac{dx_\alpha}{dx_0}=V_\alpha=const[/tex]
Wasn't he referring to the same concept of "inertial frame" as that used for a couple hundred years in Newtonian physics?
ie, a reference frame in which Newton's first law is valid, which according to Newton was valid in any reference frame "neither rotating nor accelerating relative to the fixed stars."
It seems obvious to me that Einstein was specifically referring to the same concept of an inertial frame in his postulates.
