Find the coefficient - calculus questions
The discussion revolves around finding coefficients in polynomial expressions. The first question involves evaluating g(2+h) for the function g(x) = 2x^2 – 5x, leading to the simplified expression -2 + 3h + 2h^2. The second question focuses on determining the coefficient of x in the expansion of (2x – 7)^2, which is clarified to be -28 after expanding the polynomial. Participants emphasize that the coefficient refers specifically to the term directly in front of x, distinguishing it from coefficients of other terms like x^2. The final consensus confirms that the coefficient of x in the given expression is indeed -28.
vorcil
If g(x) = 2x^2 – 5x then g(2+h) =
my working
2(2+h)^2 -5(2+h)
( 2((2+h)*(2+h)) ) - 5(2+h)
2(4 + h^2 + 4h) - 10 -5h
8 + 2h^2 + 8h - 10 -5h
-2 + 3h + 2h^2
2:
Find the coefficient of x in (2x – 7)^2.
isn't it 2?
#1 looks correct.
#2 you'll have to expand it first!
queenofbabes said:
#1 looks correct.
Find the coefficient of x in (2x – 7)2.
2x-7 * 2x-7
4x^2 - 14x - 14x + 49
4x^2 - 28x + 49
coefficient is 4-28?
so -24?
or 4, or 28
i'm pretty sure it's 4, because it's infront of the x^2, but the 28 infront of x could also be a coefficient?
Coefficient fof x is the number in front of x...so in 4x^2 + (- 28)x + 49 what is that?
there is a 4 in front of the x^2,
and -28 infront of the x.
if you meant the number infront of just the x, then it's -28
if you meant the number infront of the x, in x^2 then it's 4
which one do i choose? the power functioned x or the x without it?
i'm assuming it's the x without it because if there were more functions, like a cubic polynomial, with like ax^4 + bx^3 + cx^2 + dx + e, then it'd get confusing
so -28 is my awnser?
Yes.
But if you had
ax3+bx2+cx+d
The coefficient of x3 is a
The coefficient of x2 is b
The coefficient of x is c
and so forth.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
