Metal Shavings vs infinite lines of flux
Metal shavings appear to form discrete lines of flux due to their size and distribution, despite the absence of actual discrete flux lines. The phenomenon occurs because the shavings are not fine enough to create a smooth gradient; instead, they cluster at certain intervals. If a finer iron powder were used, it would demonstrate a more continuous distribution of flux. The discussion draws an analogy to circular disks that cannot cover a floor without overlapping, illustrating the limitations of the shavings' size. This explanation clarifies the observed pattern of metal shavings in relation to magnetic flux.
rockyshephear
You know how metal shavings form bows of flux lines. How is this possible since there are no discrete flux lines. I would think it should form a 2D gradient of shavings slowly graying out as they get further and further away. But you tend to see discrete lines as if at .4 inches there's a line of flux, and at .9 inches there's another one, with nothing in between.
It's because iron shavings aren't fine enough. If you had an infinitely fine iron powder, it would do exactly what you're saying. It's like you having an arbitrary number of circular disks, and not being able to cover your whole floor without overlapping. Sort of. Not really. Still, this answers your question.
Cool! Thanks!
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
