Radius of Curvature of a Train Turning North East
  • Thread starter Thread starter harini_5
    Curvature Radius
When a train turns from north to northeast, the outer rail's radius of curvature is greater than that of the inner rail due to the geometry of the track. The inner and outer rails are both circular, but the outer rail's radius exceeds the inner rail's by the width of the train. The discussion emphasizes that the equations for centripetal acceleration apply to point masses, while a train should be considered as a non-point mass, focusing on its center of mass. The velocity and radial acceleration remain consistent across both rails, but the curvature differences arise from their respective radii. Understanding these principles clarifies the dynamics of train movement on curved tracks.
harini_5
A train is moving towards north at one place.
it turns towards north east.
here we observe that the radius of curvature of outer rail will be greater than that of inner rail
why?pls explain
velocity and radial acc. are the same and radius of curvature=v^2/a normal
I think you are focusing too much on the equations here...
if you consider a train going about a circular track, the inner and outer rail of the track will both be circular, but the outer rail will have a radius greater than the inner rail by the width of the train.
this is all this statement is saying.
in the equation for centripetal accelleration the radius is assuming a point particle, which a train is not.
the same equation is true for a non-point-mass where the radius is then for the center of mass.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
