Calculating Force and Time with Impulse: When and How?
  • Thread starter Thread starter mahela007
    Impulse
Impulse is used in scenarios involving large forces acting over short durations, particularly in collision analysis. It represents the integral of force over time and is equivalent to the change in momentum. The concept is beneficial when direct calculations of force or time are impractical. For example, in model rocketry, total impulse ratings help estimate launch speed and trajectory height despite varying thrust during the burn period. Understanding impulse allows for effective calculations in dynamic situations where traditional methods may fall short.
mahela007
In what kind of instances would the quantity of impulse be used? My textbook says that it's when very large forces act for very short times but how would that help us calculate the force OR the time?
It is precisely when we cannot or do not need to calculate the force or the time for which it acts that we use the concept of impulse. The impulse is the integral of the force with respect to time and can be proved to be equal to the change in momentum. Here are some good sites for preliminary reading:
http://id.mind.net/~zona/mstm/physics/mechanics/momentum/introductoryProblems/momentumSummary2.html
http://www.glenbrook.k12.il.us/gbssci/phys/Class/momentum/u4l1b.html
A classical example is in the analysis of collisions.
When I was in school, I was "into" model rocketry for a while. Solid-fuel model rocket engines were rated in terms of the total impulse they produced, between ignition and burnout. The actual thrust (force) exerted varied widely during the burn period, but the burn period was short enough that you could use the total impuse to calculate good estimates of launch speed, maximum height of trajectory, etc.
Thanks
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
