Covariant Green's function for wave equation
jason12345
This comes from Jackson's Classical Electrodynamics 3rd edition, page 613. He finds the Green's function for the covariant form of the wave equation as:
D(z) = -1/(2\pi)^{4}\int d^{4}k\: \frac{e^{-ik\cdot z}}{k\cdot k}
Where z = x - x' the 4 vector difference, k\cdot z = k_0z_0 - \mathbf{k \cdot z}
He then performs the integral over k0 first by considering it as a complex variable to give:
D(z) = -1/(2\pi)^{4}\int d^{3}k e^{i\mathbf{k\cdot z}}\int_{-\infty }^{\infty } dk_0\: \frac{e^{-ik_0z_0}}{k^2_0 - \kappa^2}
where \kappa = |\mathbf{k}|
But then he says for z_0>0, e^{-ik_0z_0} increases without limit in the upper half plane.
Is this correct? There's a minus in the exponential so i would have thought it's the exact opposite.
He considers a contour r in the upper half of the k0 plane from +oo to -oo, closed by a semicircle also in the upper half of k0 and says that for z0 < 0, the resulting integral vanishes, whereas for z0 > 0, the integral over k0 is:
\oint_{r} dk_0\: \frac{e^{-ik_0z_0}}{k^2_0 - \kappa^2} = -2\pi i\: Res \left (\frac{e^{-ik_0z_0}}{k^2_0 - \kappa^2} \right) = \frac{-2\pi}{\kappa} sin(\kappa z_0)
The Green function is then:
D_r(z) = \frac{\theta(z_0)}{(2\pi)^3} \int d^3k \: e^{i\mathbf{k \cdot z}}\ \frac{sin(\kappa z_0)}{\kappa}
Where does the \theta(z_0) come from?
Thanks in advance for your interest.
Thats the Heaviside step function, which is zero for z_0 &lt;0 and unity for z_0 &gt; 0. The integral is zero for z_0 &lt;0 as you pointed out yourself, so this is just a convenient way of writing it.
jason12345 said:
But then he says for z_0&gt;0, e^{-ik_0z_0} increases without limit in the upper half plane.
Take z_0 = a + ib with a and b real, and b &gt; 0 (upper half-plane). Then
e^{-i k_0 z_0} =e^{-i a k_0} e^{b k_0},
which blows up as b becomes large.
Oops, I wrote this without reading. Often, z denotes a complex intregration variable, and I made the mistake of taking this to be so here. What I wrote above should, however, make clear what happens for complex k and z_0 a positive real.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
