Negative Feedback Example: Gain & Feedback Factor
  • Thread starter Thread starter iitjee10
    Feedback Negative
The discussion centers on an example of negative feedback in an amplifier circuit, illustrating how feedback affects gain. With an input signal of 101mV and an output of 10V, a feedback of 100mV is applied, resulting in a new input of 1mV. The gain without feedback is calculated as 10,000, while the gain with feedback drops to approximately 100. The confusion arises regarding the expected relationship between gains with and without feedback, as negative feedback reduces the input signal needed to maintain output. The explanation clarifies that negative feedback indeed subtracts from the input, aligning with the intended concept.
iitjee10
While introducing negative feedback, my book gave the following example:
Let the signal voltage be 101mV and the output voltage of the amplifier be 10V
Out of this 10V a fraction (0.01) i.e. 100mV was made to feedback to the input circuit. The feedback circuit did not introduce any phase change. Hence, the feedback was negative (there is a 180 deg. phase reversal in amplifier circuit.)
The input signal now becomes (101-100) = 1mV
Then it was given that,
Gain (without feedback) is 10V/1mV = 10,000
Gain with feedback = 10V/101mV = 100 (approx)
Feedback factor = 100mV/10V = 0.01
My doubt is that shouldn't the gain without feedback and the gain with feedback be just the opposite?
With the feedback the input becomes 1mV and without feedback the input was 101mV
They are keeping the output voltage constant and instead modifying the input signal. So with feedback, they needed a greater input signal to achieve the same output. This is to be expected with negative feedback since you are essentially subtracting off some of the output signal off from the input.
ohk... this was what was intended.
Thanks a lot Born2bwire
See complete derivation of op amp feedback and gain in thumbnail.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
