What Does 'I' Represent in the Moment Formula and How Does Tug of War Relate to Physics?
  • Thread starter Thread starter Red_CCF
    Mechanics
In the moment formula, "I" represents the moment of inertia, which quantifies a body's resistance to rotational motion. To calculate it, one must consider the mass distribution relative to the axis of rotation. In tug of war, individuals lean back to utilize their leg muscles for stability and gain mechanical advantage, preventing rotation due to ground friction. Tension in a rope is defined as the force exerted along its length, directed away from the object it supports; in a tug of war scenario, if both players exert 100N, the tension remains 100N because the forces are balanced. Understanding these concepts often requires constructing free body diagrams and applying static equilibrium equations.
Red_CCF
Hi, I've been learning about moment and there's a lot of things I don't understand
First, in the formula moment = I * alpha, what does I represent and how do we calculate it? All the formulas that I've seen are defined as M = Fr.
Also, I'm wondering, if, say, two people are playing tug of war, they are leaning back. Why must a person lean back to exert force? Also, as they are leaning back, how does couples of moments relate to the fact that they don't start spinning?
I have another problem regarding tension. What is the definition of tension exactly and how do we determine which direction it goes (ex. a rock is hanging on the rope, i know that tension goes up, but why)? Also, when the two people are pulling a rope and both are exerting 100N of force, why is the tension of the rope 100N and not 200n or 0 N
Thanks for any help that you can provide
I is the http://en.wikipedia.org/wiki/Moment_of_inertia" , a body's resistance to rotating due to a moment.
Your other questions will become clear, I think, if you look into how to construct a free body diagram (check any statics book) and how to use static equilibrium equations (e.g., the sum of the forces in the x-direction is zero, etc.).
Unless I misunderstand your first formula, what you wrote is incorrect- the torque is equal to I*alpha. The moment equation M=Fr is close to a torque=(Fr*sin(angle between the two)), but in your context 'moment' can be considered a more sophisiticated version of torque.
Have you ever played tug-of-war? Or pulled on anything heavy? You need to lean back for a few reasons: one, to engage your leg muscles and take the strain off your lower back, and two, by getting lower than the other person gives you additional mechanical advantage. You don't spin becasue of the ground.
The best explanation of tension I ever got was posted here (I forget by whom, sorry)- in order to understand tension in a rope, simply cut the rope. What happens to the ends of the rope? Does it matter where you cut the rope?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
