Concerning a pressure coefficient
The pressure coefficient, C_p, is defined as C_p = 1 - (V/V_{inf})^2, where V represents velocity. In a steady velocity field, the equation applies to the magnitude of velocity, calculated as the speed √(v_x^2 + v_y^2), rather than individual coordinates. The discussion raises the question of whether separate pressure coefficients can be defined for the x and y directions. To determine the maximum and minimum values of C_p, the overall speed should be used rather than directional components. The pressure coefficient is typically treated as a scalar quantity derived from the total velocity magnitude.
naggy
On wikipedia it says that the pressure coefficient can be written as
where V is the velocity.
So if I have given a steady velocity field, V = (v_x,v_y), does the equation for C_p hold for both coordinates or only the speed \sqrt{v_x^2+v_y^2} ?
I'm supposed to determine the largest and lowest value for C_p and I don´t know which formula to use.
Basically I'm asking if there is such a thing as a pressure coefficient in the x-direction and a pressure coefficient in the y direction?
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
