Advice for a raw graduate in the Manufacturing field?
A fresh mechanical engineering graduate has started a trainee position in a piston manufacturing company and seeks advice on navigating the industry. Key insights emphasize the importance of resilience, as production schedules are critical and the environment can be competitive. Learning from experienced colleagues and asking questions is essential for growth. Having resources like the Machinery's Handbook is recommended for practical knowledge. Overall, fostering good relationships and sharing credit is crucial for success in manufacturing.
Haroon1
Greetings,
I'm a fresh graduate with a bachelors in mechanical engineering and iv been placed in a company that produces pistons and piston rings. I've never had work experience prior to this. If there's anyone out there who's had experience in the manufacturing line or foundry work, please let me know what to watch out for. It would be very helpful for my career. I'll be joining as what any raw graduate would, as a trainee.
In manufacturing, you need a thick skin. Production is everything and schedules are king. Keep your eyes open and try to learn from those around you (same for any area of engineering). I think you will appreciate being a trainee for a while because there will be a lot of things you need to learn. Take your time learning and don't let the line workers give you too much grief about being a new engineer because you are going to hear things like "great another new engineer"...a lot. Good luck.
Make sure you have your copy of the Machinery's Handbook if you don't already. It was the best advice my professor gave me.
Its a dog eat dog business, production manufacturing
just like a dog, everybody needs a bone
when you have a good idea or project to push, make sure the boss and manager get a bone (and have a bone to take to their boss)
if you need the shop to help, make sure they get a bone
as long as eveybody gets a bone, (usually) you won't get bit
keep all the bones for yourself, they will reduce you to bones
lol..
as Fred said all that matters is what gets out the door ON time or better
and ask questions and take lots of notes (at least at first)
dr
Thanks my friends. that was some very useful advice from all of you.
dr, sounds like youve been through a very competitive environment!
Regards. :smile:
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
