What is the Divergence of a Point Charge in Cartesian Coordinates?
The discussion centers on the divergence of the electric field from a point charge in both spherical and Cartesian coordinates. In spherical coordinates, the divergence is zero, consistent with Gauss's Law, as the charge density is localized at the point charge. However, when attempting to express the electric field in Cartesian coordinates, the divergence appears non-zero, indicating a misunderstanding of the coordinate system's implications. The divergence calculation in Cartesian coordinates does not account for the three-dimensional nature of the point charge, leading to confusion. Ultimately, the issue arises from the limitations of representing a point charge's electric field in a two-dimensional plane.
hbweb500
So I am playing around with the differential form of Gauss's Law:
\nabla \cdot \vec{E} = \frac{\rho}{\epsilon_0}
Starting off simple with a point charge, the electric field is:
\vec{E} = \frac{1}{4 \pi \epsilon_0} \frac{q}{r^2} \hat{r}
And the divergence, in spherical coordinates, is:
\nabla \cdot \vec{E} = \frac{1}{r^2} \frac{\partial}{\partial r} (r^2 E_r)
= \frac{1}{r^2} \frac{\partial}{\partial r} \left( \frac{1}{4 \pi \epsilon_0} \frac{q}{r^2} \right)
= \frac{1}{r^2} \frac{\partial}{\partial r} \left( \frac{q}{4 \pi \epsilon_0}} \right)
= 0
I can handle this much. It makes sense that the divergence is everywhere 0, since the only charge density is a point charge. Griffiths has a discussion about this very thing, where he states that the infinite divergence at the origin causes things to work out as expected.
My problem is in dealing with a cartesian coordinate system. I didn't recall the divergence equation in spherical coordinates when I was first playing around with this, so I tried it in cartesian. Here:
\vec{E} = \frac{q}{4\pi \epsilon_0} \frac{ x \hat{x} + y \hat{y} }{(x^2+y^2)^{\frac{3}{2}}}
But the divergence of this is proportional to:
\nabla \cdot \vec{E} \propto \frac{-2}{(x^2 + y^2)^3}
Which clearly isn't zero everywhere. I've checked my divergence and electric field equation, but I can't find the difference between it and the spherical ones I am using.
So, what gives? Is the divergence in spherical coordinates 0, but nonzero in cartesian?
Isn't there a z axis in Cartesian coordinates? Add this and double check your divergence calculations. :smile:
Oh, yes, that would be it. I suppose the equations don't like it very much when you try to restrict the electric field from a point charge to a plane... :redface:
Thanks!
