Locally path connected implies path connected
  • Thread starter Thread starter Mosis
    Path
Mosis
We say the metric space X is locally path connected (lpc) if all balls are path connected sets.
Suppose X is lpc and that E is an open and connected subset of X. Prove that E is path connected.
A set is open if every point is an interior point. A set is connected if it cannot be written as the union of two open, disjoint, non-empty sets. A set is path connected if given any two points x,y in the set, there exists a path between them.
None really. My professor suggested that for a fixed x, I consider the set Y of all y that are path connected to x and show that this set is all of E by somehow showing that if it were not, I could disconnect the space using Y and Y complement.
I just don't see the direction that this problem could take. Is it long? Is it short but requires ingenuity? What should I try to do? Where am I trying to end up?
Help, it's hard!
It's not hard and doesn't require any stunning ingenuity. You just have to think clearly. Can you show Y is open? The main ingredient you need is that if a,b and c are three points, and a is path connected to b and b is path connected to c then a is path connected to c. Now can you show E-Y (the set of all points in E that aren't in Y) is also open? That's your disconnection.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
