Engineing Help: Controllable Powerheads for Aquariums
  • Thread starter Thread starter gajopo
    Engineering
Controllable powerheads for aquariums are significantly more expensive than standard pumps, prompting a search for a cost-effective solution. The user is attempting to create a circuit that can supply 60Hz during the "on" state and adjustable frequencies between 1-59Hz during the "off" state to reduce pump chatter and stress on aquatic life. Current methods involve using timers and relays, but the user seeks a more efficient adjustable frequency power supply. The goal is to achieve a low wattage power supply that can maintain the pump just above its stall state. Input from knowledgeable individuals in electrical engineering is requested to aid in this project.
gajopo
The application may seem trivial, but I need to control an aquarium powerhead (pump). I'm an elevator adjuster by trade and have no problem understanding schematics and scouring datasheets but am by no means an electrical engineer.
My issue simplified, controllable powerheads cost 8-10X the cost of the same flow 120vac single speed synchronous pumps. Their ac counterparts are simple, two coils, one with a few extra turns to get the permanent magnet impeller to turn in the desired direction. Problem is with the interval timing circuit I am using the causes the pumps to "chatter" upon excitation stressing my much loved salt water inhabitants. Yes I could spend 1500$ on Tunze controllable pumps with a controller, but I like the 150$ approach better if possible.
What I would like to accomplish is a circuit that would supply 60hz during their "on" state and 1-59hz during their "off" state, slowing them to near their synchronous stall state (1-59hz, maybe 17hz??...). 60Hz is simple as I am doing that now.
How can I make a 120vac (+- 40v) 1-59Hz power supply? I have been scouring the internet for days and decided to just start posting were someone with the knowledge may see this and give me something I can plug into Electronics Workbenches MultiSim for trial and error.
For those of you who may care, a Hydor Koralia 4 (What I'm using) costs 30$. A Tunze Stream starts at 329$ plus the 12vdc controller. Both pump water, one just capitalizes on control via a large price hike.
Any input is greatly appreciated!
Gary
When you say interval timing circuit, is it just a circuit to turn them on and off at different times during the day?
Right now I am using 2 .1 to 99 second in-line timers and 2 relays. The pumps are on opposite sides of the tank set at 12 seconds, simulating the ebb and flow found in natural reefs.
Sounds like a soft starter is what you would need, can't say whether they are available for motors of that size though.
There is my problem. Single phase soft starts require specific motors with special windings, centrifugal switches, capacitors and on...
If I can find a way to make a 120vac adjustable frequency low wattage power supply I can supply on its hysteresis(off) state to slow the pump motor just above stall I will achieve my goal. At least that's my theory!
I do appreciate your interest! Keep asking.
Gary
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
