Why did they use these formulas for energy of electron.
The discussion focuses on the energy calculations for electrons in an electron microscope, specifically how to achieve a wavelength of 10.0 pm. The initial confusion arises from the use of the equation E = hv = hc/lambda, which applies to photons, rather than the appropriate equations for massive particles like electrons. To find the energy, it's necessary to first determine the velocity of the electrons using lambda = h/(mv) and then calculate kinetic energy with KE = 0.5mv^2. The distinction between photons and electrons is crucial, as electrons should not be treated as photons in these calculations. Understanding this difference clarifies the correct approach to solving similar problems in the future.
cloudage
An electron microscope employs a beam of electrons to obtain an image of an object. What energy must be imparted to each electron of the beam to obtain a wavelength of 10.0pm?
1. E = hv=hc/lambda
2. lambda = h/(mv)
3. KE = .5mv^2
In this problem I thought you could use the first equation to find the energy with the specific wavelength of 10pm. However, the workbook goes through equations 2 and 3 to first find the velocity and then find the kinetic energy. The answers come out very different, so I must be thinking wrong. Can anyone help me understand this?
Since I am solving for energy, why do I need to go through equations 2 and 3?
cloudage said:
1. E = hv=hc/lambda
This only applies to photons.
2. lambda = h/(mv)
3. KE = .5mv^2
For an electron, you'll need these two equations.
So whenever they say "electrons" I need to use them? That makes sense, I figured the electrons were being emitted as photons so I thought of them as photons.
Thank you for your help, I see why I got the wrong answer on a couple of other problems now too:smile:
For any kind of massive particle. (A photon has no mass.)
Yikes, don't do that. :wink:
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
