Eigenvalues: Matrix corresponding to projection
shiri
Let A be a matrix corresponding to projection in 2 dimensions onto the line generated by a vector v.
A) lambda = −1 is an eigenvalue for A
B) The vector v is an eigenvector for A corresponding to the eigenvalue lambda = −1.
C) lambda = 0 is an eigenvalue for A
D) Any vector w perpendicular to v is an eigenvector for A corresponding to the eigenvalue lambda = −1.
E) Any vector w perpendicular to v is an eigenvector for A corresponding to the eigenvalue lambda = 0.
A) A matrix must have a non-zero eigenvalue.
B) The vector is an eigenvector of corresponding to the eigenvalue.
C) See A
D) When a vector is perpendicular to A, it must be zero for eigenvalue (If it was nonzero eigenvalue, then it is not perpendicular)
E) See D
So far I believe A, B, E are true? What do you think? Please help me.
Thanks for giving reasons this time, but I don't believe A) is true. And I believe your reason even less. Let's just start from there. A matrix doesn't HAVE to have a nonzero eigenvalue, much less (-1). I will say your answers to D and E seem to be correct, but if you think E is true, then why do you think C is false? That's just crazy.
When I read the textbook, it stated that "a square matrix A is invertible if and only if lambda = 0 is not an eigenvalue of A."
Therefore, I assume C) was false.
After I read your message, it appears that B, C, E are correct for this problem?
Who said A was invertible? I'm not going to tell you what's correct until you convince me you know what's correct. Why do you think B is true?
I would say that eigenvector corresponding to the eigenvalue λ = -1 is any multiple of the basic vector. So, both make the eigenspace corresponding to the eigenvalue.
or
The eigenvector corresponding to the eigenvalue λ = −1 is the solution of the equation Ax = -x
If you project v onto the line generated by the vector v (which is what A does to v), what do you get? They aren't talking about just any vector that happens to have eigenvalue -1. They are talking about that particular v.
I would get linearly indepedent eigenvectors, Dick?
Do you know what a projection is? http://www.freewebs.com/xinyeeisme/ProjectionVectors_1000.gif That picture shows you the projections of some vectors onto the line generated by the vector w. What's proj_w(w)?
proj_w(w) = ((w (dot product) w)/w)/||w||^2, isn't?
Right. So what is Av if A is the projection onto the line generated by v?
It will be parallel? so, there are many vectors that could correspond to the given?
That means C and E are true, right?
Av is (v.v)v/|v|^2. (v.v) is the same as |v|^2. Av is v!
Therefore C and E are true, right?
Av=v has nothing to do with whether C and E are true or false. It's about a different part of the problem.
