Metals with what type of crystal lattice less prone to brittle fracture?
nocturnalgod
Metals with what type of crystal lattice less prone to brittle fracture? Why?
What makes a metal ductile? What is the difference between ductile and brittle?
Tensile strength...
My answer would be Steel (AISI 1060 0.6% carbon), because it has the highest ultimate tensile strength for a metallic lattice at 2,200-2,482 MPa and density 7.8 g/cm^3.
Tungsten is at 1,510 MPa and density 19.25 g/cm^3.
[/Color]
Reference:
http://en.wikipedia.org/wiki/Tensile_strength#Typical_tensile_strengths"
Ductility occurs in materials where valence shell electrons are not rigidly bound and are thus shared. These electrons atoms to slide past each other without breaking. It occurs under tension.
Brittleness is the tendency of a material to fail under stress, usually tension, rather than deform. It's not normally applied to shear. Generally, if there is little or no plastic deformation before failure, the material is said to be brittle.
Malleability is similar, but not identical, as it involves deformation under compression. Gold, for example, is both ductile and malleable, but lead is only malleable.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
