Hubble's constant and decelaration parameter
doive
I've been measuring hubble's constant by calcultaing the redshift on a star and it's distance from Earth using a simple method of assuming galaxies have a standard size, then measuring their apparent size to gauge their distance away.
To refine the model i have been asked to include a deceleration parameter q0. I have found an equation relating q0 to Hubble's constant but I'm confused by one of the terms, the 'angular diameter distance'. What is it and what is it actually measuring?
d_a= \frac{c}{q_0h_0} \frac{zq_0+(q_0-1)(\sqrt{(2zq_0+1)}-1)}{(1+z)^2}
it tells me to use q0=0.1 or 0.5 or 0.8 and plot da against z and check which value of H0 fits the data. q0 seems to just be an arbitrary number? is it just an expansion coefficient for the universe expansion?
Now i can see that as i increase q i increase the "bend" of the line produced, but as i change H0 i just change the gradient, which I'm not sure really helps me at all?
questions in summary:
What is "angular diameter distance"?
surely there is only one value for H0 so how do i "see which fits the data"?
what is q0? it seems to just be arbitrary?
Sorry for a lot of confusion, but I've not taken any astronomy before but have changed courses and have been set this as "catch-up" over, i also have no astronomy textbooks since i hadn't been doing it until recently.
The angular diameter distance is a unit of distance used often in astronomy. Wikipedia has a good article explaining it further, but it basically is that
<br /> d_A=\frac{x}{\theta}<br />
where d_A is the angular diameter distance, x is the actual size of the of the object in question and \theta is the angular size of the object.
Aaaah i get it now
Since i have already worked out x from measurement i am in fact using that as the relation to z.
I think my problem previously wad that i was using the value i had calculated for Ho to work out dA rather than the other way about. You're explanation was very simple but it made it click , thanks :D
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
