Low Battery Charge: The Physics Behind What's Happening
Devices can regain some charge when turned off due to physical processes in batteries and capacitors. Batteries often deplete near electrodes first, and when left unused, reagents can diffuse back, allowing for a temporary charge recovery. Capacitors can also exhibit "memory" effects, retaining some charge even after being discharged, due to dielectric absorption. This phenomenon, known as "soakage" or "voltage retention," indicates that capacitors and batteries behave differently under load and over time. Understanding these mechanisms can help users manage device performance and battery longevity effectively.
Pythagorean
I've noticed that some devices (when they're low on battery charge) can be shut off and will regain some charge while they're off (if you leave them off long enough).
What's going on here, physically?
Some capacitors can recharge slightly after apparently being completely discharged, due to "memory". The only safe large capacitor is one with the two terminals shorted together. Any unshorted capacitor should be treated as though it were (or was) charged. I consider it to be long-term time constants in the dielectric.
Bob S
[added] Look for phrase Dielectric absorption (or DA), sometimes called "soakage", "voltage retention", and other things. In high-voltage power cables it´s called "return voltage". A capacitor, once charged, stubbornly retains part of the charge, even after being discharged (shorted for some number of seconds), as if it had "soaked" into the dielectric. in
http://my.execpc.com/~endlr/
Batteries don't deplete their reagents uniformly, particularly under heavy loading. They are depleted near the electrodes first, and as the reagent concentrations near the electrodes falls the battery appears to be flat. When left unused for some time the reagents will have time to diffuse from higher concentration regions deeper within the cell toward the lower concentration regions near the electrodes and the battery therefore appears to have spontaneously regained some charge.
Bob S
Yeah, I have a giant capacitor I'm working with to make an EM cancrusher (peak 14 kV). I definitely keep the terminals shorted. Still, I'm curious of how the charge separation physically reoccurs (assuming that's what's happening in this case).
With batteries, I've seen this at an elementary level.
In that case, it was due to a collection of bubbles on the surface of one of the electrodes.
When the bubbles cleared, more of the electrolyte liquid could contact the metal electrode and the voltage rose accordingly.
Because this was happening in a glass beaker, the problem was easily visible.
I guess something similar happens in commercial batteries. They do tend to recover slightly after being taken off load for a while.
I had the same problem on a Lithium Ion (?) I bought to replace the one I'd had in my Palm PDA (TIP: buy third party or even 'OEM' batteries from reputable sellers, eBay or otherwise). I think it's probably poor battery performance under load (and for extended duration, with warming, etc.). That or it doesn't match the expected charge profile. Either way, if this device is still under warranty, you may want to look into it.
This is probably also dependent on what the 'restoration' is like. Mine would auto-shutoff and then, 10 minutes later, report 90% charge.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
