Work Required to Empty a Hemispherical Tank
  • Thread starter Thread starter Precursor
    Empty Tank Work
Precursor
Find the work required to empty a tank in the shape of a hemisphere of radius R meters through an outlet at the top of the tank. The density of water is p kg/m^{3}; the acceleration of a free falling body is g. (Ignore the length of the outlet at the top.)
The attempt at a solution
w = \int_a^b (density)(gravity)(Area-of-slice)(distance)dx<br />
w = \int_0^R (p)(g)(\pi)(R^{2})(R - x)dx<br />
Is this correct/complete?
Hi Precursor! :smile:
(have a pi: π and a rho: ρ and an integral: ∫ and try using the X2 tag just above the Reply box :wink:)
No, that's the correct formulal for a cylinder (Area-of-slice = πr2).
Try again! :smile:
So is the area of the slice actually π(1 - x²)?
Nooo (btw, it might be easier if you measured x from the top instead of from the bottom :wink:)
Is it π√(R² - x²)?
Precursor said:
Is it π√(R² - x²)?
With x is measured from the top, yes :smile: except …
lose the square-root! :wink:
(and I'm going to bed :zzz: g'night!)​
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
