I'm partially color blind. Is this a problem?
  • Thread starter mkarger
  • Tags
    Color
In summary: There are going to be some issues that you will have to take into account when looking for a job after you graduate, but I don't think that they will be significant. The only things that you may have a problem with are reading CFD (colorful fluid dynamics) plots and reading electrical schematics. However, if you have the appropriate training, you should be able to overcome those issues.Overall, I think that you will have no problems finding a job after you graduate.
mkarger
56
I'm considering changing my major to either electrical or mechanical engineering.
However, I fail all color blindness tests. It always shows that I'm red-green color blind. But, I never have any issues deciphering different colors or hues. It seems as my brain has adapted to compensate for my color deficiency.
Am I going to have a tough time finding a job after I graduate?
I doubt it. The only issues you might have is reading CFD (colorful fluid dynamics) plots.
I can read current flow diagrams and astronomical spectrographs perfectly fine. So I assume I can read pretty much everything else.
I need a LOT of help passing those tests, although in real-life I can easily tell the difference between reds and greens. When the sample is small and far enough away, in addition to them being pale shades, then I have issues.
However, one thing I've noticed on those tests is that often times you (we'll) be able to see half of the number. For example, an 8 will look like a 3. There are other little things like that. So, if for any reason you're concerned about not passing the test, take that in mind.
Although I highly doubt that color blindness would ever be a reason for not employing a person.
p.s. Wow, did I just post about kind of cheating a color blindness test?
So you can tell the difference between red and green but can't pass the colour blindness tests? I don't understand this blindness very well. Is it impossible for you to notice the number on the page?
Hi, mkarger,
Sorry to hear about your red/green color sensitivity problem:
If you haven't been clinically diagnosed, this http://www.webmd.com/eye-health/tc/color-blindness-topic-overview" may be informative and of help to you.
Rhody...
I used to work with an electrical engineer who was color blind. He had trouble reading the color codes of resistors so he always checked them with an ohmmeter. Nowadays with the prevalence of surface mount devices, even that shouldn't be a problem. Can you discern the difference between the various color LEDs?
I am also red green color blind. I had a problem some years ago while driving through Mississippi. The traffic lights had only two bulbs one above the the so that the red light would be on the top coming one way and on the bottom coming the other. I didn't whether I should stop or go. I was luky that my brother was in the car with me to tell my if I had the right of way.
I am a retired electrical engineer and never had a problem with color codes.
Yea, weird, huh? I cannot for the life of my get the number. The last one I did for my most recent work physical had me literally guessing numbers. Some of the numbers, though, I could make out half, as in the example I mentioned above.
I cannot see any numbers except for the ones that show up for red/green color blindness.
On occasion, I have a problem deciphering hues of brown from green and hues of purple from red. But that very rarely happens. I can see every color in the rainbow perfectly fine.
rhody said:
Hi, mkarger,
Rhody...
I've already been diagnosed by my eye doctor. She said that my brain has adapted to decipher different colors even though I am technically red/green color blind. Which means that I see color. It's just different from what everyone else sees.
1. What exactly does it mean to be partially color blind?
Being partially color blind means that you have difficulty distinguishing between certain colors. This can be due to a variety of factors, including a genetic condition or a problem with the functioning of the eye or brain.
2. Is being partially color blind a serious problem?
It depends on the severity and type of color blindness. In most cases, it is not a serious problem and can be managed with minor adjustments. However, in rare cases, it can impact daily activities and may require special accommodations.
3. Can partially color blind individuals still drive?
Yes, partially color blind individuals can still drive. However, they may need to take additional color vision tests to obtain a driver's license, and they may need to rely on other visual cues such as the position of traffic lights and signs.
4. Can being partially color blind be corrected?
In some cases, partially color blindness can be corrected with special lenses or glasses. However, this is not always possible and depends on the underlying cause of the color blindness.
5. Will being partially color blind affect my job opportunities?
This will depend on the specific job requirements and the extent of your color blindness. In some industries, such as graphic design or certain types of art, color vision may be essential. However, there are many other career options that do not require perfect color vision.
  • Biology and Medical
  • Electrical Engineering
  • Science and Math Textbooks
  • STEM Academic Advising
  • STEM Career Guidance
