Allowed energies for electrons in hydrogenic atoms
manenbu
I have a question which may seem stupid, but I think I missing something here.
I see 2 equations describing allowed energies for electrons in hydrogenic atoms, being:
E = -\frac{hcRZ^2}{n^2}
And
E = -\frac{RZ^2}{n^2}
I assume that both are correct, but what makes the difference? Is it the same R for both of them? or the second R includes the h and c inside?
How would I tell the difference?
Please enlighten me. Thanks :)
And
They are trying to express the same relation, and you are correct that in the second version, the h and c have been "absorbed" into the R. In the first case the dimension of R is 1/length, and R comes from the Rydberg formula for the wavelength of a photon coupling two H-atom energy levels. In the second case, the dimension of R is energy, and the R stands for the Rydberg unit of energy, which is defined as the ground state energy of the H-atom in the approximation of infinite nuclear mass. The atomic unit of energy, the hartree, is exactly two Rydbergs.
Ok, thank you.
It's just that some textbooks use either one, and none explain the difference.
Now I understand!
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
