Ray matrix - refraction at a curved surface
The discussion focuses on deriving the refraction matrix at a curved convex surface with radius of curvature R, separating two media with refractive indices n1 and n2. The correct refraction matrix is established as \left[\stackrel{1}{\frac{1}{R}\left(\frac{n_1}{n_2}-1\right)}\stackrel{0}{\frac{n_1}{n_2}}\right]. Participants emphasize the importance of using the refraction equation {r_t2}={R_2}{r_i2} and the transfer matrix \left[\stackrel{1}{\frac{d_2_1}{n_t_1}}\stackrel{0}{1}\right] in the derivation process. The discussion highlights the need for careful computation at the interface due to the angle of incidence.
  • Understanding of refraction principles and equations
  • Familiarity with matrix representation of optical systems
  • Knowledge of curved surface geometry and radius of curvature
  • Proficiency in approximations involving Taylor series, specifically \sqrt{1-{x^2}}{\approx}1-\frac{x^2}{2}
  • Study the derivation of the refraction matrix for different geometries
  • Explore the application of transfer matrices in optical systems
  • Learn about the implications of curvature on light propagation
  • Investigate the use of Taylor series in optical physics
Students and professionals in optics, physicists working with light refraction, and anyone involved in the design of optical systems that utilize curved surfaces.
8614smith
The diagram shows a curved convex surface with radius of curvature R separating two media with differing refractive indices of [tex]n_{1}[/tex] and [tex]n_{2}[/tex]
Show that the matrix representing refraction at this surface is [tex]\left[\stackrel{1}{\frac{1}{R}\left(\frac{n_1}{n_2}-1\right)}\stackrel{0}{\frac{n_1}{n_2}}\right][/tex]
In your derivation you may assume that [tex]\sqrt{1-{x^2}}{\approx}1-\frac{x^2}{2}[/tex] and that the slope of a curved surface [tex]\theta_s[/tex] may be approximated by [tex]\theta_{s}{\approx}\frac{dx}{dy}[/tex]
refraction matrix: [tex]{r_t2}={R_2}{r_i2}[/tex] where [tex]{R_2}=\left[\stackrel{1}{0}\stackrel{-D_2}{1}\right][/tex] and [tex]{D_2}=\frac{{n_t2}-{n_i2}}{R_2}[/tex]
Transfer matrix: [tex]\left[\stackrel{1}{\frac{d_2_1}{n_t_1}}\stackrel{0}{1}\right][/tex]
using the refraction equation i have got to [tex]\left[\stackrel{1}{0}\stackrel{-\frac{{n_2}-{n_1}}{R}}{1}\right][/tex] and using the transfer matrix i got [tex]\left[\stackrel{1}{\frac{R}{2n_2}}\stackrel{0}{1}\right][/tex]
I'm not too sure what to do from here, I've multiplied them both by each other both ways round and neither way got the right answer, I am unsure even whether this is the right way to do it.
i assume that the aprroximation it gives has something to do with the equation of a circle but i don't know how to use it...
You will have to use the refraction equation, but you need to be careful when computing the refraction at the interface since the interface is at an angle. So it is dependent on [itex]y_1[/itex], assuming [itex]y[/itex] is your interface axis.
Also since it is an interface, you know [itex]y_1=y_2[/itex] so the top of the matrix is (1 0). The bottom of the matrix will take some work.
