Lennard-Jones Potential - distance of closest approach
The discussion focuses on finding the distance of closest approach for two atoms in a Lennard-Jones potential, utilizing energy conservation principles. The equation derived leads to a quadratic form that provides two roots, one positive and one negative. The positive root corresponds to the physical distance where the atoms interact, while the negative root raises questions about its physical interpretation, possibly relating to a virtual turning point or tunneling effect. The participants note that the presence of a negative solution is problematic, as it cannot represent a physical distance. The conversation emphasizes the need for clarity on the implications of these roots in the context of atomic interactions.
xn_
Here's my solution to the problem of finding the distance of closest approach for two atoms approaching each other in a Lennard-Jones potential, starting with velocities (+/-) v_0:
They start with energy T0 = (1/2)m(2v02) which is conserved. Thus,
E = T + V = (1/2)m(2v2) + A/r12 - B/r6 = T0. At the distance of closest approach, v=0 and we have:
T0 = A/rt12 - B/rt6. If we let x = rt6 and rearrange:
T0x2 + Bx - A = 0
which has the solutions
x = (1/2T0)(-B +/- sqrt(B2 + 4AT_0)
My question is - what, physically, do each of these roots correspond to? They're both real, but of opposite sign - is the negative one a kind of 'virtual' turning point for the atoms passing through each other (tunnelling?) and coming out the other side?
The solutions are not all real. You have defined ##x=r_t^6##. Note that the solution ##x=\frac{1}2{T_0}(-B-\sqrt{B^2+4AT_0})## is negative assuming of course that A and B are positive. That cannot be for an even power of a number.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
