Quick question about an object hanging from a string?
  • Thread starter Thread starter sameeralord
    String
An object hanging from a string remains stationary when the tension in the string equals the object's weight. This tension arises from the string's elasticity, which stores energy as elastic potential energy. If the string loses its elasticity due to excessive weight, it may not generate tension, causing the object to fall. When the string becomes plastic, energy is converted to change its structure, potentially leading to permanent deformation. Even with deformation, tension can still exist as the string undergoes changes under load.
sameeralord
Hello everyone,
If an object is hanging from a string in the wall. It is stationary so this means tension of the string and weight force of the object must be equal. Is this tension coming from the elasticity of the string. So if the string loses its elasticty by a heavy force, does that mean there would no be a tension foce and the object would keep going down and fall to the ground. When the spring is elastic it stores its energy as elastic potential energy, when it becomes plastic like, is this energy converted to change the structure of the object.
Right, if you hang too much weight from the string, the force goes into breaking bonds in the fibers, or overcoming the friction between the individual fibers that are twisted together and allowing them to slip.
An ideal string, within its rated load, would undergo reversible changes such as bending (not dislocating) atomic bonds. The reversibility is what gives it "potential energy".
--John
The tension could also result in permanent deformation, but there will still be a tension.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
