Diagrammatic Tensor Notation from the Beginning
LukeD
I've posted this in the Geometry & Topology section, but I believe it will get many more views here, so I'm posting a link
Pictures here:
https://www.physicsforums.com/showthread.php?t=407776
I really liked Penrose's diagrammatic way of writing tensor algebra, so I spent a while learning the basic notation. Unfortunately, it took a very long time for me to learn this because there is so little info on it to begin with. I also didn't see much mention of how to use the notation for doing numerical computations.
So since I want to be able to use the notation for everything that I should be able to do with tensors, I figured that I'd start at the very beginning of algebra and use the notation. My plan is to write a little tutorial that teaches everything from how to write numbers, vectors & covectors to how to take integrals.
The notation for adding tensors is mine as far as I know, and I've changed some other notation here and there.
I have 14 pages done, but they are very rough. So far they are very basic ideas. Should I continue with this? Any suggestions for cleaning it up? I want to make it as short & simple as possible while still getting the point across.
Can you teach me how to konw it
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
