Castigliano's method for calculating displacements
  • Thread starter Thread starter Dell
    Method
Castigliano's method for calculating displacements relies on the strain energy of a structure and its relationship with generalized forces. The discussion highlights that for non-symmetrical cross sections, applied forces may cause displacements not aligned with the force direction, particularly when the force is not on a principal axis. A cantilever beam with an "N" shaped cross section demonstrates this, as a force applied along the y-axis results in movement in both y and z directions. There is uncertainty about whether to decompose the applied force into principal axis components to accurately calculate displacements. The conversation emphasizes the importance of understanding the shear center's role in displacement outcomes.
Dell
Castigliano's method for calculating displacements is an application of his second theorem, which states:
If the strain energy of a linearly elastic structure can be expressed as a function of generalised force Qi; then the partial derivative of the strain energy with respect to generalised force gives the generalised displacement qi in the direction of Qi.
is this only correct for forces working on the principal axes?? up till now i have not been dealing with nonsymetrical cross sections but now that i have started it is clear that if i have a nonsymetrical cross section with a force only in one direction, my displacement will not be in that direction but rather perpendicular to the neutral axis. (unless the force is on one of the principal axes)
taking for example a simple cantelever beam with an "N" shaped cross section on plane zy, if a force is applied on the y-axis the cross section will move in both y and z directions. if i used castiglianos theorem i can find a displacement for the y axis(not sure if this is the correct displacement) but to find the z displacement i would usually add a fictitious force (Q=0) compute the internal forces as a function of Q and integrate, but since Q=0, i would simply get displacement=0
do i need to divide my real force into its principal axes components, find the derivative of each one and integrate?
If N is the cross section and if N is in the yz plane then your load on the y-axis passes through the shear centre. Doesn't that mean that there is no displacement in the z-direction?
