Trigonometry - Finding equation of line
  • Thread starter Thread starter Telemachus
    Line Trigonometry
The discussion focuses on finding the equation of a line that passes through point P(2,1,3) and intersects line L perpendicularly, as well as determining points A and B on line L to form an equilateral triangle PAB. The user has calculated the height of the triangle using trigonometric functions but is confused about the relationship between the height and the base of the triangle. Clarifications are provided regarding the sine and cosine values associated with the angles of the triangle, emphasizing that the sine of 60º cannot exceed 1. The user is guided to correctly relate the lengths of the triangle's sides to find the necessary points A and B on line L. The discussion highlights the importance of understanding trigonometric relationships in solving geometric problems.
Telemachus
Consider P(2,1,3) and the line L: \begin{Bmatrix}x-y-5=0 \\z-1=0 \end{matrix}
a) Find the equation of the line that pass through P and cuts L on a perpendicular angle.
b)Finds the points A and B in L in a way that PAB being an equilateral triangle.
I've solved A, and I'm trying to solve b. I think that it can't be much difficult, cause I know all of the interior angles of PAB. I have a trigonometric problem. I've calculated the distance from L to P, so I got the high of the triangle. So, I know that sin 60º=h, I got h=\sqrt[ ]{22}, so what I know is that sin 60º=\sqrt[ ]{22}, so the cosine would be the half of the base. How should I get the base?
I've found L2: \begin{Bmatrix}x=2+5\mu \\y=1+7\mu \\z=3+4\mu \end{matrix}. So, I need to find the points A and B on L.
No, sin 60º is the height divided by the hypotenuse, the distance from P to either A or B, not just h. And since you do not yet know what A or B are, you do not know that distance.
Fortunately, since sin(60º)= \sqrt{3}/{2}= h/hypotenuse, hypotenuse= 2h/\sqrt{3}. And, of course, the base is equal to that so the distance from the foot of the perpendicular to the line from P is half the length of the hypotenuse.
Excuse me, but \sqrt{22} is almost 5 and a sine cannot be larger than 1! No, sin(60º)= \sqrt{3}/2. You can get that by dividing an equilateral triangle into two right triangles with angles 60º and 30º. If each side of the equilateral triangle has length L, then each right triangle has hypotenuse of length L, one leg, opposite the 30º angle, of length L/2, and the other leg, opposite the 60º angle, of length \sqrt{3}L/2[/itex], by the Pythagorean theorem.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> <h2>The Attempt at a Solution</h2><br /> I&#039;ve found L2: \begin{Bmatrix}x=2+5\mu \\y=1+7\mu \\z=3+4\mu \end{matrix}. So, I need to find the points A and B on L. </div> </div> </blockquote>
Thanks HallsofIvy.
So, what I got is that x=\displaystyle\frac{\sqrt[ ]{22}}{sin 60º}, and that's the length of the sides of the triangle, right?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
