Can the 2nd ode x*y''-c*y=0 be solved exactly?
  • Thread starter Thread starter sufive
    Ode
sufive
As the tittle, can the 2nd ode (B.C not fixed, I need the general solution)
y''-c/x*y=0
be solved exactly? Or can it be translated into some
special mathphysical equations, such as Bessel?
Hypergeometric? etc
any comments or references are welcome.
Thank you for advance!
Would this work?
<br /> <br /> y&#039;&#039; - \frac{cy}{x} = 0, can be rewritten as
\frac{dydy}{y} = \frac{c}{x}dxdx, which upon integrating gives
ln|y|dy = c*ln|x|dx, and then we would just have to integrate one more time?
I would go with a series solution, with y = c0 + c1x + c2x2 + ... + cnxn + ...
Don't you need to search for a solution not from the type:
<br /> y(x)=\sum_{n=0}^{\infty}a_{n}x^{n}<br />
but from the form:
<br /> y(x)=\sum_{n=0}^{\infty}a_{n}x^{n+r}<br />
<br /> a_{0}\neq 0<br />
because of the singularity at x=0 ?
I don't think it is possible to find both linearly independent series' if you search the solution in the first form, I couldn't. but may be I'm rusty in the Olde ODE's :)
Raskolnikov said:
Would this work?
No, that is not valid.
\frac{d^2y}{dx^2}\ne \frac{(dy)(dy)}{(dx)(dx)}
but from the form:
The equation as originally given is xy'' - cy = 0, which is defined when x = 0. It is only by dividing by x that you introduce an singularity.
Thans to all of you. Your browse or reply helps me.
To this point, LCKurtz's message is the most nearest to
my need!
No, this DE has a regular singular point at x = 0. gomunkul51 is correct about the form the infinite series would take. See
http://banach.millersville.edu/~bob/math365/singular.pdf
for the definition of a singular point and discussion.
You might also try a change of variables to transform the differential equation into the Bessel differential equation. For instance, u=sqrt(x) gets you a differential equation that sort of looks like the Bessel differential equation.
