Battery that stays charged for 30 years.
A new type of battery utilizing radioisotopes could potentially last for 30 years without needing a recharge, primarily powered by the decay of radioactive materials. While such batteries are already in use for space probes and remote stations, their low power output limits broader applications. Technologies like SNAP generators and semiconductor-based nuclear batteries have been explored, but issues such as damage to semiconductor materials from energetic particles pose significant challenges. Concerns about safety and the practicality of using these batteries in everyday devices, like laptops, are also raised. Overall, while the concept shows promise, further advancements are necessary for practical public use.
blimkie.k
I "stumbledupon" this article this morning.
A battery that used radioisotopes and is powered by the decay of the radioactive material. Sounds like it would work. Is this legit? If so it seems like a pretty serious innovation. I'm sure this battery if developed for the public would have a lot more use then just laptops.
http://www.stumbleupon.com/su/1PJfLa/www.dodevice.com/2007/10/02/one-laptop-battery-that-lasts-30-years-without-recharge/
Yes they exist - they are used to power some space probes and used to be used for remote navigational/weather stations
They have very low power for their size and weight.
I've known of three technologies for generating electricity directly from nuclear decay. Back in the late 50's or early 60's, the SNAP generators were developed. They used the heat from the decay to heat one side of a thermo-electric module/modules which in turn produced electricity.
The Soviets had a technology using the decay to heat a column in a kind of vacuum tube such that thermo electric emmission delivered current.
Then, there is the holy grail of nuclear batteries which uses semiconductors (like solar cells) to capture energy directly from particles emitted by the nuclear decay. This sounds like the proposed technology. It has suffered a major setback though - the energetic particles damage the semiconductor crystal causing it to loose performance after a short while.
Though i didn't want one of those in my lap one hour a day. Or are the beta rays sufficent shielded?
Anyone know the Wh/kg ratio on these?
As I remember from Physics, Beta Rays are simply electrons which may be moving really fast. They don't have much in the way of penetrating power and find a sheet of paper (?) a challenge.
I suspect that in the process of being blocked, they produce soft x-rays, which in turn are easily blocked.
As for Wh/kg, I'm pretty sure that's determined by something other than the fuel :)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
