Fortran Fortran: creating array containing characters
  • Thread starter Thread starter _Andreas
    Array Fortran
To create an array of characters in a programming context, the initial attempt using a fixed dimension for the character array was unsuccessful. The correct approach involves defining a character string with a specified length and then populating a character array by iterating through each character of the string. The solution involves declaring a character variable for the string, an array for the characters, and using a loop to assign each character from the string to the array. This method effectively converts a string into a character array, allowing for better manipulation of individual characters.
_Andreas
Hello.
I'd like to create an array containing characters (basically a word stored as a 1xn array). I have no idea how to do this, however. I thought that the most obvious way to do it (yes, it would've been highly impractical for long words) was to write
character, dimension(3) :: A
A=[F,P,G]
but that doesn't work at all. Any suggestions?
Technology news on Phys.org
Ok, problem solved. If anyone's interested, this is how you do it:
character(len=n) :: string
character, dimension(n) :: array
integer :: i
string="blablabla and so on"
do i=1,len(string)
array(i)=string(i:i)
end do
Likes camila
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
12K
