The Conjugate Method for Limits
The discussion centers on the use of the conjugate method for evaluating limits, particularly when faced with expressions that yield a zero in the denominator. It highlights that while the conjugate method can simplify certain limits, it may not always resolve the issue of a zero denominator, especially when the numerator contains a function like f(x). The examples provided illustrate that both the conjugate method and factoring can lead to similar results, raising questions about their distinctiveness and applicability. The conversation emphasizes that multiplying by the conjugate is meant to create common factors for cancellation, but this approach may not be effective if the numerator is not conducive to simplification. Ultimately, the discussion seeks clarity on whether there are specific scenarios where one method is preferable over the other.
charley076
I'm reviewing limits to tutor a student in precalc and came across a problem.
The conjugate method multiplies the numerator and denominator by the conjugate of the numerator or denominator to simplify the equation. However, after a quick example I wrote for myself, I found that:
lim x-> 3
f(x) / (x-3)
Conjugate Method on the Denominator
lim x-> 3
f(x)*(x+3) / (x^2-9)
The limit still has a 0 in the denominator
lim x-> -3
f(x) / (x+3)
lim x-> -3
f(x)*(x-3) / (x^2-9)
The examples of "The Conjugate Method" that I've found online have all multiplied by the conjugate to create a common factor to eliminate the 0 in the denominator.
Ex.
lim x-> 4
(sqrt(x)-2) / x-4
Conjugate of Numerator
lim x-> 4
x-4 / ((x-4)(sqrt(x)+2)
Cancel common factor
lim x-> 4
1 / (sqrt(x)+2)
=1/4
My issue is that the conjugate method is the same as the factoring method as far as I understand it. Is there a difference or is the conjugate method simply easier to use when the factors aren't as easily identifiable.
My point using the example above is:
lim x-> 4
(sqrt(x)-2) / x-4
Factor the denominator into (sqrt(x)-2) & (sqrt(x)+2)
lim x-> 4
(sqrt(x)-2) / ((sqrt(x)-2)(sqrt(x)+2))
Cancel (sqrt(x)-2)
lim x-> 4
1 / (sqrt(x)+2)
= 1/4
Is there a difference between these methods?
Is there a time when only one or the other can be used?
Mathematics news on Phys.org
In your first two examples, you have f(x) in the numerator, so multiplying the expression by 1 in the form of the conjugate over itself isn't going to get you anywhere.
The purpose of multiplying by the conjugate over itself is to be able to get common factors in the numerator and denominator that you can eliminate in the hope of being able to evaluate the rest of the limit expression.
Sorry for the confusion, the reason I put f(x) as the numerator was b/c i didn't know what to put there that wouldn't cause the limit to evaluate to infinity. I just meant f(x) to be filler, i.e. regardless of what the numerator is, multiplying top and bottom by the conjugate of the denominator doesn't resolve the 0 in the denominator.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
