How to calculate compound percentage change
  • Thread starter Thread starter drdoug
    Change
To calculate the final percent change over a period with varying percentage changes, multiply the factors derived from each percentage change. For example, for a 3% increase, use 1.03, and for a 3% decrease, use 0.97. The overall formula is 100 times the product of these factors minus one. This method allows for efficient calculation without needing to compute each year's change individually. Understanding how to incorporate both increases and decreases is crucial for accurate results.
drdoug
Example: Inflation over time
Supposed that I want calculate the final percent change in a 10 year period.
(year , % Change) --> (1,3) (2,4) (3,7) (4,3) (5,2) (6,5) (7,4) (8,3) (9,4) (10,6)
How should I calculate the final percent inflation without having to calculate one by one?
Mathematics news on Phys.org
100 ( 1.03 * 1.04 * 1.07 ... * 1.06 -1 )
sorry for my laziness but how would you calculate with negative values?
Each term in the above product is (1 + %change/100).
So for a 3% change (increase) the product term is 1.03, for a 3% decrease you would use 0.97 and so on.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
