Instantaneous and Average Rate of Change of f(x) | Interval (0,3)
To find points in the interval (0,3) where the instantaneous rate of change of f(x) equals the average rate of change over [0,3], first calculate the average rate of change using the formula (f(3) - f(0)) / (3 - 0). For the function f(x) = 4x^2 - x^3, this results in an average rate of change of -1.5. The derivative, f'(x) = 8x - 3x^2, represents the instantaneous rate of change. Setting -1.5 equal to the derivative leads to a quadratic equation that can be solved for x to find the required points.
pyrosilver
Find any and all points inside the interval (0,3) where the instantaneous rate of change of f equals the average rate of change of f over the interval [0,3], for the equation
f(x) = 4x^2 - x^3
Not really sure how to do this. How do I find the average rate of change over that interval? I was thinking take the derivative:
f'(x) = 8x - 3x^2
plugging in 0 and 3 to get f'(0) = 0, and f'(3) = -3. So the average rate of change would be
-1.5?
And then saying
-1.5 = = 8x - 3x^2? I don't know, gah. How do I solve this problem?
Based on how I see things, you're quite nearly there! You've just ended up with a quadratic equation, now what do you do?
Derivatives are the instantaneous rate of change. Your book should have a formula (a very familiar looking formula) for average rates of change.
f(x) = 4x^2 - x^3
f'(x) = 8x - 3x^2
-1.5?
And then saying
No, what you've written is not the "average rate of change". The average rate of change of a function f over the interval [a; b] should be calculated as follow:
\frac{f(b) - f(a)}{b - a}
Hopefully, you can go from there, right? :)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
