Finding x in a geometric progression, given the sum.
  • Thread starter Thread starter NotaPhysicist
    Geometric Sum
The discussion revolves around finding the value of x in the infinite geometric series 1 + 2x + 4x^2 + ... = 3/4. Participants clarify that the series is indeed infinite, which allows the use of the formula S_infinity = a / (1 - r), where a = 1 and r = 2x. Attempts to solve the equation lead to confusion, with one participant mistakenly believing it was a finite sum. Ultimately, the correct approach involves recognizing the infinite nature of the series and applying the appropriate formula to find x. The conversation concludes with participants gaining clarity on the problem's requirements.
NotaPhysicist
If
1 + 2x + 4x^2 + ... = \frac{3}{4}
find the value of x. [Edit: Forgot to ask the question]
S_n = \frac{a(1 - r^n)}{1 - r}
t_n = ar^{n-1}
a = 1
r = 2x
I try to solve S_n and end up with
2x^n = \frac{6x - 7}{4}
which I can't solve.
I try to solve by equating t2 and t3 and getting x = (1/2). Which is wrong.
Any help appreciated.
Is the sum is to infinity?
or to 'n terms'?
If it is to infinity, Apply limit to your equation.
NotaPhysicist said:
If
If this is an infinite sum the formula is
S_\infty= \frac{a}{1- r}
If it is a finite sum, you would need to know how many terms so that "n" would be an actual integer, not a variable.
The "..." at the end of the sum indicates it is an infinite sum.
t_n = ar^{n-1}
a = 1
r = 2x
I've edited the original post. The problem is to find the value of x.
Its not an infinite sum. The only solution I can see is to solve for n in the infinite series and the summation, and try to solve simultaneously.
I had to read your answer a couple of times. I get it now. Its an infinite sum. No powers to work out.
Thank you so much.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
