How Fast Must the Rock Be Thrown to Reach the Naturalist?
  • Thread starter Thread starter kalupahana
    Fall Free fall
The discussion revolves around calculating the minimum initial speed required for a pet rock to reach a naturalist being lifted by a hoist. The naturalist is 2.50 meters above her friend, who throws the rock upwards while the naturalist moves at 2.03 m/s. Key equations of motion and energy conservation principles are applied to derive the necessary calculations, with emphasis on equating the rock's kinetic energy to the naturalist's energy at her height. Participants suggest using conservation of energy for a more straightforward solution, while also considering time and displacement factors. The conversation highlights different approaches to solving the problem, ultimately focusing on energy conservation as the preferred method.
kalupahana
Free fall, problem, please help
A hoist is lifting a naturalist to the top of a cliff at 2.03 m/s vertically. The naturalist suddenly realizes she has left her pet rock behind. A friend picks it up and tosses it straight upward. If the naturalist is 2.50 m above her friend, what is the minimum initial speed the pet rock must have to reach the naturalist?
(consider gravitational acceleration as 10ms-2 & air resistance negligible)
s = ut + ½ at2
v= u + at
v2 = u2 + 2as
Here u is initial velocity & v is final velocity
The information of problem as follows
....The hoist......pet rock
u ....2.03....... ?
v...2.03....... ?
s ...2.5 + x......2.5 + x
t ...?....... ?
a...non.......-10
the both time & displacement should be equal
So the displacement of hoist
2.5 + x
The get minimum initial velocity the final velocity should be 0.
v = u + at
0 = u - 10t
t = u/10
the u is equal to
v2 = u2 + 2as
u2 = 20(2.5+x)
the displacement is equal to
s = ut + ½ at2
2.5 + x = ut - 5t2
from here i don't have any idea, please help me.
What is the time of hoist when pet rock reach
2.5 + x = 2.03t
t = (2.5 + x)/2.03
or
x = 2.03t
t = x/2.03
which one i should take
Well I would try to use conservation of energy.
When the naturalist is at the height 2.50m she is traveling at 2.03m/s, so she has a total energy associated with that. Now in order for the rock to reach that high, it must be imparted with kinetic energy equal to her total energy at that height.
If you're looking for the absolute minimum initial velocity, then at the end its velocity will be zero because at the apex of its flight the rock will be stationary for a split second where the naturalist can grab it.
WOW!
I had previously approached the prob a bit like kalupahana(and got the answer) did but this is much better!
Thanks!
The legend said:
WOW!
Thanks!
Normally, for these kinds of problems, I try to use conservation of energy unless I am directly asked to find a time parameter.
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
