Can Somebody Explain These Steps for Me(answer given, dont get steps in between)
  • Thread starter Thread starter imapeiceofwod
    Explain
imapeiceofwod
2.45 and 2.55 i don't get the steps, on how they get to the final answers, can someone explain please.
http://ea2.mccormick.northwestern.edu/homework/hw1-sol.pdf
2.45 The vector sum of the forces is zero. This means that every component of the sum of force vectors is zero, i.e: sum of Fx = 0 and sum of Fy = 0.
Split F1,F2 and F3 into their horizontal and vertical components.
Sum of Fx is the sum of all horizontal components of the forces.
Sum of Fy is the sum of all vertical components of the forces.
Both of these should be zero.
You have two equations and two unknowns. Solve for these unknowns.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
