How do you convert from one line equation to another?
  • Thread starter Thread starter Andy21
    Convert Line
The discussion focuses on converting the line equation y - 2 = 4x - 4 into the equivalent form 4x + y - 6 = 0. It is clarified that the two equations are indeed equivalent, with the transformation involving rearranging and multiplying by -1. The original question also seeks to find the equation of the tangent line to a circle at a specific point, which is confirmed to be 4x + y - 6 = 0. The correct approach includes using implicit differentiation to find the slope at the given point. The conversation emphasizes the importance of accurately calculating the derivative to determine the tangent line's slope.
Andy21
Show how the equation of a line y-2=4x-4 can be converted into the equivalent line equation of 4x+y-6=0.
The closest I have got to it is 4x-y-2=0 by adding and subtracting terms to both sides.
It can't. These two equations aren't equivalent.
y - 2 = 4x - 4
<==> y - 4x + 2 = 0
I got this by adding -4x and +4 to both sides.
This equation is equivalent to the one you show below. Multiply the equation above by -1 on both sides and you'll get an equation that can be rearranged to yours.
Thanks for the help. The reason I asked this question is to find the equation of the tangent to the circle (x+3)^2 + (y-1)^2=17 at the point (1,2). I know the answer to this is 4x+y-6=0. Can you explain to me how to get this answer.
That answer is correct. I think you made a mistake in calculating the derivative. The slope of the tangent line at (1, 2) is -4, not 4, as you show.
Yes sorry, what I asked in the original question was wrong. Can you explain how to get the answer 4x+y-6=0 for the equation of the tangent from the circle equation and the point I gave in my previous reply. Thanks.
1. Find dy/dx using the circle equation. I used implicit differentiation.
2. Evaluate dy/dx at (1, 2) to get the slope of the tangent line.
3. Use the slope found in step 2 and the point (1, 2) in the point slope form of the line.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
