Newbie Quantum Physics Questions
Wong
Hi all,
I started on my physics program this semester. But things begin to puzzle me much, especially quantum mechanics. I hope that you wuold take the time to answer a few of my puzzles.
I used Sakurai's book in my quantum mechanics course. It is said that in the position space, the mometum eigenkets takes on the plane wave form. This result is independent of potentials. So does it mean that if we place a particle in whatever potentials, as long as we are able to measure the momentum accurately, then it should be equally probable to find the particle at any point in space (at later times)? This puzzles me because the result seems to hold even when the particle is in an infinite potential well, where classically the particle cannot penetrate. I know the uncertainty relation requires this, but it just seems strange, because the energy eigenfunction on the other hand cannot penetrate into that region...
The other question is like this. Suppose a particle is subjected to a potential and we measure the position of the particle as it goes along. If we let the time interval tends to zero, we would be able to find a path of such a particle as a function of t. It seems that we would be able to obtain the velocity of the particle from such path. Of course we cannot because in doing so we would ascribe properties to the system additional to that contained in the wavefunction. But this reminds me of some strange brownian motion. Brownian motion is continuous yet (almost surely) non-differentiable. Is it possible that as the time interval tends to zero, the particle takes on such a path?
My third question is the quantum description of the double slit experiment. The double slit experiment for particles is always explained in a manner similar to light waves by ascribing the de brogile wave length to the particle. I wonder how might it be described in the quantum language. Is it like the barrier with the two slits are treated as a "sheet" with infinite potentials with two openings (zero potential). Is it true then that the particle is in the energy eigenstate?
All comments are appreciated. Thanks in advance!
Regards,
Jamie
Have you taken any other QM courses? If this is your first class in QM, and your class is using Sakurai's Modern QM text, then I have a question for you and your instructor: "ARE YOU NUTS?!" :)
This text should not be used for beginning QM class. It is way too advanced and requires that you already have a clue about basic QM.
Read Thomas Marcella paper that painfully derived ALL the so-called wave interference phenomena using photons without having to invoke the properties of the classical wave of light.[1]
Zz.
[1] T.V. Marcella, Eur. J. Phys., v.23, p.615 (2002).
So, "this semester" means you've been in physics for about 2 weeks now? Personnally, I did a lot physics before starting QM. I assume you did math or enginneering or chemistry already and are starting graduate studies. Sakurai is usually not seen before the last year of a physics program, if at all.
"It is said that in the position space, the mometum eigenkets takes on the plane wave form. This result is independent of potentials. So does it mean that if we place a particle in whatever potentials, as long as we are able to measure the momentum accurately, then it should be equally probable to find the particle at any point in space (at later times)? This puzzles me because the result seems to hold even when the particle is in an infinite potential well, where classically the particle cannot penetrate. I know the uncertainty relation requires this, but it just seems strange, because the energy eigenfunction on the other hand cannot penetrate into that region..."
Nothing prevents a plane wave to be 0... In other words, even though the wave has to be a plane wave, it doesn't mean it has to be non-zero. When there is an infinite barrier, boundary conditions are imposed so that the plane wave is 0 beyond the barriers. This is aloud since dpsi/dx doesn't have to be continuous at the boundary of an infinite potential.
In this special case, there can be no tunneling, neither classically nor quantum mechanically. (In real life, there are no infinite barriers, so tunneling is always analytically possible.)
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
