Why Does Gravity Affect Weight?
Weight is determined by the gravitational pull of the Earth on an object, which is influenced by the object's mass. According to Newton's law of gravitation, the force of gravity between two objects is directly proportional to the product of their masses and inversely proportional to the square of the distance between them. This explains why a heavier object, like a bowling ball, experiences a greater gravitational pull compared to a lighter object, such as an apple. Therefore, an increase in body mass results in a greater weight due to the stronger gravitational force acting on it. Understanding these principles is essential for grasping basic physics concepts.
QTip
Hi. I'm an absolute noob at physics, so I went to the library and checked out a couple beginner books. Basic Physics: A self-teaching guide and Science 101 Physics.
I'm just getting started reading physics 101 and read the following statement:
"...all you have to do to determine your weight is step on a scale. What is actually being measured in this case is the gravitational pull of the Earth on your body."
It then goes on to talk about your weight on other planets, etc.
I'm wondering why the Earth pulls harder on me when I'm fatter. I hope that question makes sense. I just can't see why the gravitational pull is greater for a bowling ball than it is for an apple.
Thanks for any clarification.
You said you are starting physics now...So start it and go on further you get to know why it is on your..
from Newton's gravitational law , gravity between two objects proportional to the product of the masses directly and inversly to the square of the distance between them,.,,,
So you conclude why a ball is pulled with greater force that an apple or why you weigh more when you are fatter...(means more mass)
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
