Why Does the Moon Glow? Causes of Illumination
  • Thread starter Thread starter dirtypunk
    Glow Moon
The moon appears to glow due to sunlight reflecting off its surface, which has a relatively low albedo of about 14%. This low reflectivity means it only reflects a small portion of the light that hits it, making it resemble sunlit coal against a dark sky. The moon's brightness is more pronounced at night when contrasted with the blackness of space. During the day, it appears dimmer as it blends into the brighter daytime sky. Overall, the moon's illumination is a result of sunlight and its reflective properties.
dirtypunk
why does the moon appear to glow from our view on earth? what causes the illumination?
Astronomy news on Phys.org
The sun
A flashlight and an orange will also let you work out why we see cresent, full and half moons
Yes the reason it glows is the sun but the cause is because the surface of the Moon has an extremely high albedo (high-reflectivity).
The moon has rather low albedo, only reflecting ~14% of the light that hits it...similar to coal. It looks bright at night because it's lit by the sun against a black sky...it's like a lump of coal, but sunlit coal, in an otherwise perfectly dark room. (okay, a smattering of tiny, dim pinprick lights for the stars)
When seen in the day, with your eyes adapted to sunlight, it's much dimmer, largely blending in with the daytime sky.
Yep. Coal... Pavement...
Although it does reflect more than a diffuse flat 0.12 albedo surface so it's not really a fair comparison - it's far from a Lambertian reflector.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
