Why Is One Side of a Diode Heavily Doped?
  • Thread starter Thread starter elimenohpee
    Diodes
In diodes, one side is heavily doped to ensure effective electrical contact and improve conductivity, particularly at the junction where metal contacts connect to the semiconductor. The heavy doping on the p-side in standard diodes and the n-side in LEDs facilitates Ohmic contacts, which are essential for optimal device performance. This doping reduces the depletion region's impact, allowing for better current flow and efficiency. Additionally, in bipolar junction transistors, heavy doping enhances minority carrier injection, improving current gain. Overall, the primary reason for heavy doping is to achieve reliable electrical connections and enhance device functionality.
elimenohpee
Can someone explain why in diodes one side of the junction is heavily doped, namely the p-side in a standard diode, resulting in a p+n junction? Or in an led where the n-side is heavily doped? I can't seem to find the reasoning behind this anywhere.
Doping is what gives a material (silicon, for example) it's "semiconducting" properties... If you didn't dope it, it'd be more or less an insulator.
Then you don't have to worry about depletion on the heavily doped side, i.e. it's negligible
Sigh. How about a real answer.
The heavier doping, you will notice, is typically in drain and source areas where metal contacts are connecting them to other parts of the circuit. Or for other technologies like bipolar, you'll have an extra implant of heavier doping at all the contact points.
http://wpcontent.answcdn.com/wikipedia/en/thumb/6/62/Cmos_impurity_profile.PNG/500px-Cmos_impurity_profile.PNG
http://sub.allaboutcircuits.com/images/03302.pngSo, primarily the heavy doping is to assure an Ohmic contact, rather than a rectifying contact. Metal-Semiconductor junctions are diodes with depletions layers, etc., after all. Find the section in your semiconductor physics text about Ohmic contacts and it will become clear.
The other reason can be seen in the bipolar example: the buried N+ layer for improving collector resistance: highly doped == better conductivity. Sometimes you'll see "sinker" implants which are an extra N+ implant from the collector's contact N+ down to the buried layer. In this HBT patent, #106 is a sinker to contact the buried layer #102 for the collector implant #104. The actual collector contact would go on top of #106 overlapping a bit of the oxide #110.
http://www.freepatentsonline.com/7183627.htmlOne place where this heavy doping actually hurts is in the drain because you'll have a tiny depletion layer which means extremely high fields. This causes Hot Carrier Injection to occur which damages the MOSFET gate oxide over time (and is the primary failure mechanism above ~200 nm design rules). For this reason, Vdd values were dropped from 5 V to 3.3 V and lower years ago and things like LDD and DDD implants became standard to spread out the drain depletion layer and reduce the HCI creating fields.
You'll see heavier doping in bipolar emitters. The reason for this is that it improves the asymmetry of minority carrier injection which directly affects the beta or current gain of the device. The high doping assures that reverse injected minority carriers are quickly recombined. The lower base doping gives the minority carriers more chance to reach the base-collector depletion layer and become collector current. In the EM or GP models, this means the reverse characteristics are attenuated giving better overall forward device performance.
These are secondary to the ohmic contact reason though obviously important.
In the HBT example above, using a heterojunction Base-Emitter diode kicks butt on a simply PN junction Base-Emitter so the N+ emitter doping becomes moot.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
