Converting Numbers/Letters to ASCII Codes
  • Thread starter Thread starter jjlee2
The discussion revolves around a program that converts characters to ASCII values but fails to handle more than four inputs, resulting in zeros for subsequent entries. The code snippet provided shows the program structure, including data declarations and the main routine. Users suggest using a debugger, specifically PCSpim, to step through the program and observe register and memory values. It is noted that the program stores the first four characters correctly but fails to store additional characters, leading to confusion about memory allocation and register use. Participants emphasize the importance of adding comments to the code for clarity and understanding. Questions arise regarding the purpose of certain variables and the logic behind decrementing the input counter. Overall, the discussion highlights debugging techniques and the need for clearer code documentation to resolve the issue.
jjlee2
hi i have a program that reads in numbers or letters and converts them to ascii but it will only work for up to 4 items and after that i just get zeros, here's the code for the program
.data
x: .byte 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
y: .word 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
total: .word 0
str1: .asciiz "
Enter a character "
newln: .asciiz "
str2: .asciiz "Character Decimal Value "
str3: .asciiz "Enter total number of values: "
space: .asciiz " "
.text
.globl main
main: la $s0,x
la $s1,y
li $v0,4
la $a0, str3
syscall
li $v0,5
syscall
sw $v0,total
lw $s2, total
loop1: slti $t0,$s2,1
bne $t0,$zero,out
li $v0,4
la $a0,str1
syscall
li $v0,12
syscall
sb $v0,0($s0)
addi $s0,$s0,1
addi $s2,$s2,-1
j loop1
out: lw $s2,total
la $s0,x
lw $s3,0($s0)
loop2:
slti $t0,$s2,1
bne $t0,$zero,done
andi $t1,$s3,255
sw $t1,0($s1)
srl $s3,$s3,8
addi $s1,$s1,4
addi $s2,$s2,-1
j loop2
done: la $s0,x
la $s1,y
lw $s2, total
li $v0,4
la $a0,newln
syscall
li $v0,4
la $a0,newln
syscall
li $v0, 4
la $a0, str2
syscall
loop3: slti $t0,$s2,1
bne $t0,$zero,fin
li $v0,4
la $a0,newln
syscall
li $v0,11
lb $a0,0($s0)
syscall
li $v0,4
la $a0,space
syscall
li $v0,1
lw $a0,0($s1)
syscall
addi $s0,$s0,1
addi $s1,$s1,4
addi $s2,$s2,-1
j loop3
fin: jr $ra
thanks in advance for any help with this problem
Technology news on Phys.org
Do you have any kind of debugger to work with? It would be very helpful to be able to single-step through your program and see what values are in memory and in the various registers.
Also, you don't have a single comment in your program. Assembly programs by their very nature, should have lots of comments.
yes I've been using pcspim to run it, and that has a single-step function
Does the debugger in PCSpim show you the values of the registers and memory? If so, you could single-step through your program and see what happens after you enter the fourth character.
i have done that and it starts putting the 5th through 8th in the next register the first four numbers are stored like so 0x64636261 then the fifth and sixth are stored in the next register like so 0x00006665. then it separates the values like so 0x00000061 0x00000062 0x00000063 0x00000064 0x00000000 0x00000000 and doesn't put the 65 and 66 into the last 2
Code:
main: la $s0,x
la $s1,y
; prompt user to enter total number of values
li $v0,4
la $a0, str3
syscall
; read integer from keyboard
li $v0,5
syscall
; store word in $v0 at address total
sw $v0,total
; load value at total into $s2
lw $s2, total
bne $t0,$zero,out
; prompt user to enter a character
li $v0,4
la $a0,str1
syscall
; read a character from the keyboard
li $v0,12
syscall
; store the character at address $s0 + 0
sb $v0,0($s0)
; increment $s0 pointer
addi $s0,$s0,1
; decrement $s2 pointer - ?
addi $s2,$s2,-1
j loop1
I have taken the first part of your main routine and added comments to help me understand what it is doing. I used ; to start a comment, which might not be the correct MIPS syntax. It would be an excellent idea for you to correct any comments that I have that are incorrect, and put in comments for the rest of your program. That would help both of us understand what is going on.
The first thing your program prompts for is an integer, which represents the number of characters you are going to enter. What are you entering for this value?
You aren't being very clear here about what you are doing. When you say "next register" which one do you mean? I'm not there looking at the debugger with you, so you need to be very specific about what you're seeing.
It looks like to me you entered 1, 2, 3, 4, 5, and 6. The ASCII values of these characters are 0x61, 0x62, 0x63, on up to 0x66. Each of these numbers will fit into a byte. Is the idea that the characters you enter go into the x storage, and their ascii codes go into the y storage? I don't understand what those two variables are used for.
Near the end of the block of code I copied, you have addi $s2,$s2,-1. Why are you doing this?
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
Thread 'Project Documentation'
Trying to package up a small bank account manager project that I have been tempering on for a while. One that is certainly worth something to me. Although I have created methods to whip up quick documents with all fields and properties. I would like something better to reference in order to express the mechanical functions. It is unclear to me about any standardized format for code documentation that exists. I have tried object orientated diagrams with shapes to try and express the...
