Probability of Faulty Battery: Shop 1 vs. Shop 2 - Homework Help
  • Thread starter Thread starter matt222
    Probability
The discussion revolves around calculating the probability of faulty batteries from two shops, with 75% from shop 1 and 25% from shop 2. The initial calculations suggest a total faulty rate of 11%, but this approach is incorrect as it fails to consider the distribution of batteries from each shop. A more accurate method involves using a sample of 10,000 batteries, leading to 325 faulty batteries in total, with 75 from shop 1 and 250 from shop 2. This results in a faulty battery probability of 3.25% and a conditional probability of 0.75% that a faulty battery came from shop 1. The discussion emphasizes the importance of applying Bayes' Theorem for accurate probability assessments.
matt222
Two shops where
75% of battery come from shop 1
25% of battery come from shop 2 also
99% from shop 1 ok
90% from shop 2 ok
1- what is the probability that a particular battery is faulty
2- given that its faulty, what is the probability it came from shop 1
for question 1 it is 0.01+0.1=0.11%
for the second one is 0.01
is it true
Not true - you need an approach that takes into account the percentages of batteries that come from the two shops. Think about that, and show a little more work. (Hint: have you discussed tree diagrams? Bayes' Theorem?)
The simplest thing to do is to imagine you have 10000 batteries (chosen just to avoid fractional batteries). 75% of 10000= 7500 are from shop 1 and 25% of 10000= 2500 are from shop 2. 1% of the batteries from shop 1 are faulty so you have 1% of 7500= 75 faulty batteries from shop 1 and 10% of the batteries from shop 2 are faulty so you have 10% of 2500= 250 faulty batteries from shop 2.
You have a total of 75+ 250= 325 faulty batteries out of 10000. What percentage is that?
You have a total of 325 faulty batteries and 75 of them are from shop 1. What percentage is that?
for the first one going to be 3.25% and for the second one is 0.75%, is it right
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
